So today I got a red flash screen with “LOW COOLANT” pop up. Bit concerning considering my old GTD had coolant issues..
No drip puddles etc. Haven’t digged around properly, anyone know if coolant has UV light sensor bits in it anymore?
Hoping that it’s an airlock, gone to the pub to let the car cool and unscrew the cap... fingers crossed!
Check the level and top it up, these cars a re notorius for having air locks even from factory. Has exact same thing driving down through franc, panicked as thought it would be the dreaded water pump as I was on 10k miles from new. Topped it up when I got to my destination (thankfully I'd done 95% of the 1,000 mile drive). Then it never used any after that. Done 17k now.So today I got a red flash screen with “LOW COOLANT” pop up. Bit concerning considering my old GTD had coolant issues..
Yesterday really...
So massive thanks again to the gents at VAG Manchester and Progressive Parts. Those people following my build thread know my car was under power at the Dyno day, so the car is visiting RacingLine in just over a week. So just to annoy me it pinged for a service.
They don’t normally do services at a weekend, but due to some other projects, @PP Mark agreed to fit me in and at short notice too. So got the Haldex done as well. Filter was not bad after 17k, considering other photos I’ve seen:
Thanks to also to @PP Gareth for the entertainment, and Tom for all the hard work on the car!
Excuse my ignorance, but what's the picture of?
What is a typical cost for the Haldex service and at what mileage should it be done? Thanks in advance.
Gave the old pipes a scrum and polish
What did you use on these? They look great!
It is, and dealers say they don’t need doing. Tuners say around 10k. I’ve seen pictures of ones a right mess, but the mechanic Tom thought I’d had it done at it last Service it was that clean. (It’s done 17k without being done)Worked it out. That's the pump filter.
Its the same engine.
wow, that's a nice little touch. Where did you get the lights from and where did you connect them?Fitted ambient lighting below air con panel and above rear USBs in centre console....
View attachment 12923 View attachment 12924
I used these.....wow, that's a nice little touch. Where did you get the lights from and where did you connect them?
