Guys how i can change my monitor to play video format ? first i must take a full link option right? and then can i fix it from odb11?
I can confirm the sport dials work in my 2019 Seat Ibiza FR Sport
@Jonathan Bassett
look this video
Have you discovered this new menu' in cdb?
automatic closing of windows when locking
Its a option for auto closing windows. I have this also on my ibiza 6F. Look for fenster closing BAP. Its at the end of the adaptions options.
Verstuurd vanaf mijn SM-G965F met Tapatalk
I have tried too many times and i have made the encodings without the encoding for the voice in the radio cdb... Look...
https://sendvid.com/mfig16pq
I have seen what you have said to find in the adaptations.. But nothing!
I have find in zv komfort adaptation..
Bap komfotschliben
But i don't know if is it!
Bap komfotschliben
No look for the option Fenster or type this in the search option in vcds. Then it show. In vcds this option is on the end of the adaption screen. Done few cars wirh this option also mine.
Also activated mirrorlink in motion on android phone.
Reactions: Ghost45
At0ny, i do not have vcds i have odbeleven.. Is not the same!
Probably yes but in obd the encodings are hidden and the menu are the same...
But for adaprions they are all the same.
Security acces code 31347 then adaptions and then look for the right adaption channel to change. (Look for fenster channel)
I tried activating cornering fogs, both via the apps function on OBD11 & via long coding. Neither worked.
Long coding activated fogs to ON constant, with dipped beam.
So coded it back to standard.
Wrong coding.. its not a longcoding.
Need to code leuchte 12 and 13 lightfunction C to abliegelicht, dimwert 100%.
Also check AFS vorschrift is this is ECE119.
New encodings found !
Automatic closing of the windows upon locking (one click of the remote control):
Central Electric 09
Adaptations
1) Zv comfort
Komfortschliessen Brasilien ---> active
Bap Komfortschlieben--->active
2) Spiegelverstellung
Funk_Spiegelanklappung_Modus: cambiare il valore su "by_look_command_via_remote_control_key" [Standard: "by_convenience_operation_via_remote_control_key"]
Motorized car mirrors
Central Electrics 09
Adaptations
Spiegelverstellung
Automatic closing of the mirrors when the car is closed
Menuesteverung funk spiegel anklappen--->active
Spiegelanklappen bei Wiederverriegelung -->active
Variants:
1) Spiegelanklappung geschwindigkeitsabhaengig ---->moving mirrors folding function
2) Spiegel ausklappen ueber ffb auf ---->mirror folding function with only panel inserted
Lowering mirrors in reverse [Not Runnig actually]
Menue Spiegel absenkung ----> Active
Spiegelabsenkung bei rüeckwäertsfahrt----> Active
UPDATED THE FIRST PAGE !!
Sorry yeah I meant adaptions, I used this thread as a reference but it didn’t work.
Automatic closing of the windows upon locking (click of the remote control):
Central Electric 09
Adaptations
Zv comfort
Adaptations
Spiegelverstellung
Enter the variants:
Mirror lowering reverse does not work..
Ibiza/arona 6F, polo Aw/Troc tested on these cars. There is no module 52 to activate this..
