Best Bulbs For LCR
Johny
52
Hi all, what bulbs are you using for your Leons? At the moment I've got some basic ones in i think they're Osram's longlife but the vision on them isnt really great. I need some that have the highest range as i drive at night times a lot on all types of roads that i never was before so dont know them and not having enough range makes me paranoid as it did happen to me once that there was a sharp bend without any marking or road signs warning you ahead , scared the hell out of me Any tips will be appreciated thanks.
Odesláno z mého SM-N960F pomocí Tapatalk
mkrowlatt71
31
I use night eye led ones. Really bright, especially at night. Don't think they'll go through mot though. Have to change back to standard ones for MOT.
Sent from my ONEPLUS A5000 using Tapatalk
Reactions: Johny
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
I’ve been using these for over 3 years.
Excellent. Decent pattern( although I did renew light clusters too. )
I’ve never been flashed by oncoming traffic, by dazzling them.
Most led bulbs seem to dazzle. Mine seem to be pretty good
Also led high beam which light up everything.
And led sidelights and f
ogs. Although fogs are better with halogens for visibility.
Not failed an mot yet.
This is standard beams.
Badger5 Custom Map + TIP,
Reactions: Johny
Johny
52
These do look to have a decent range, how do they fit with the plastic cover tho, does the connection clear it or do you have to make a hole in it? Cheers
