Manual Cupra owners, what is your clutch like?
GeoffGeoff
191
40
Not related to your car at all as I only have the 1.5 but I noticed the clutch is very light and engages around 60-70% which is about same as my last car but I prefer a lower and more positive engagement myself...seems they’re made for light engagement for traffic these days.
Reason for my post - does anyone know if the Leon’s have a clutch delay valve (or are they fitted to specific models of the Leon if not the Cupra)?
Damo H
4,707
2,817
Car Length In Front
Normally you get 600nm when you pass 2bar of boost and get 500hp.
So this one is quite funny :)
Remember his is a Cupra R 310 so there are likely a few things different on his car. I know in theory it’s just an ECU tweak, but even his engine mount was different to other Cupras.
Also as there were several cars run at the sane time you got to see a comparison of his car against others.
Reactions: paddy6789
paddy6789
1,627
1,082
Preston, Lancs
I know the Cupra has them, as I’ve had mine removed, and I’m also going to remove the clutch assist spring under the clutch pedal:
https://www.autoinstruct.com.au/man...mk7-golf/mk7-golf-clutch-delay-valve-removal/
https://www.autoinstruct.com.au/manufacturer/volkswagen/mk7-golf/mk7-clutch-assist-spring-removal/
There’s no indication of what model it applies to or whether it’s all manuals.
Sent from my iPhone using Tapatalk Pro
Reactions: GeoffGeoff
Ken H
161
8
Cork , Ireland
2016 Car has done 64,000 Km with absolutely no issues. I don't track the car, I've never timed the car. How anybody gets through a clutch in 10k is beyond me. Drive it like you stole it springs to mind.
GeoffGeoff
191
40
Thanks Paddy!
Did you notice much of a difference/a better clutch feel after removing? I might look into this as it feels quite vague at the moment.
paddy6789
1,627
1,082
Preston, Lancs
Thanks Paddy!
It’s hard to tell if it made any difference because I had it removed at the same time of having my clutch upgraded. So it was always going to feel different after that.
QTom
77
16
Just an update: I got the car back from the dealer. They inspected everything to do with the clutch and said it's all good.
Guess I'm getting used to the clutch now as it felt better on the drive home. Shame I'm stuck working from home now so I'm not really even getting to drive it.
Aug 11, 2021
8
Hi Guys,
just had mine replaced. Now have a sach sintered 4 paddle clutch with new bearing and sach OE DM flywheel. Car drives fine, however when pulling away when the car is warm I get a chattering noise, is this normal?
cheers Lewis
Fishbowlhead
Mk3 CupraST 280
Nov 20, 2020
148
80
UK
465 lbft / 630nm of torque - not sure what stage 3 is yet
Jesus, yours awd or fwd?
When I bought mine from Marshals the clutch was slipping at 41k, which they replaced under warranty, I rarely gun the car so will probably last years, they did the flywheel at the same time on a total replacement.
paddy6789
1,627
1,082
Preston, Lancs
Sorry, just seen this. It was fwd.
