Mine is top view / 360. Handy for parking in lined off areas, get it right first time. Kerb parking doesn't totally
help although you can cut to the wing mirror down image. Depends on the level of street lighting for top view to work on kerb parking in the dark.
Reversing with top view is handy in the drive where I can follow the grass line round as I turn. Look at the overall left image for that one rather than the rear view, that comes in to get the final place without hitting the wall...
Top view is worth having in the
Ateca if it's an option since its a high car so tricky to get placement right. Stops faffing around parking. The overall top image is meshed together from the four cameras re projecting the images. Full ultra sound is worth having although neither doesn't totally protect you from bollards etc that don't represent a full even plane in front or behind the car.
I've white lined the
garage
. Even if you haven't got top view white lining the back position allows you to see how much of the car is in the
garage and it's placed correctly. Just put it in reverse to check once in if you haven't got top view. Partners approach.
The boards have people moaning about seeing their number plate and not seeing their number plate in the reversing image. 360 camera is pretty good at not showing the number plate. The number plate moan I reckon is connected to the standard camera. Seeing it and not seeing the plate I reckon is due to the white bar "safe to move" covering it up... then they get excited about it on boards that they can sometimes see it and other times not
