hi dan. thank you for your reply. when i open the door it disappears and the clock display kicks in... nothing in the car manual about this also. it appears when i close the switch and the doors are closed.I have never seen that one it seems like some sort of expand option.
If you have a door open whilst on that screen the you should see an option of vehicle status, see if the button does anything then.
I'm sure if you touch it it will leave the infotainment on for a bit with ignition off, or it's the other way round ie will close it down and touching the big X will leave it on, hope that makes sense.hello
does anyone know what this icon on my multimedia means?
thanks
The cross in the other corner closes that page, so you can continue using the infotainment without the ignition being onI'm sure if you touch it it will leave the infotainment on for a bit with ignition off, or it's the other way round ie will close it down and touching the big X will leave it on, hope that makes sense.
thanks. will try nowI'm sure if you touch it it will leave the infotainment on for a bit with ignition off, or it's the other way round ie will close it down and touching the big X will leave it on, hope that makes sense.
after checking no difference when the icon pressed or not on the screen time... hope to find out eventually what it doesthanks. will try now
yes i know the cross allows that but what is that icon mean??? strange and curiousThe cross in the other corner closes that page, so you can continue using the infotainment without the ignition being on
i dont see any faults... and even if so, what does this icon means?I remember having something similar when I was getting a message in the Driving Data, Vehicle information......about faults recorded and saved in the infotainment app.
I am sure I had something similar? And it was telling me a fault was logged on the cars system.......when I went into the driving data It was showing faults being logged of the driving aids ( which was the reason the control unit was changed on the recall ) I will check on mine to see if I have the same icon as yours.i dont see any faults... and even if so, what does this icon means?
ok thank you. i will check if i have any faults as wellI am sure I had something similar? And it was telling me a fault was logged on the cars system.......when I went into the driving data It was showing faults being logged of the driving aids ( which was the reason the control unit was changed on the recall ) I will check on mine to see if I have the same icon as yours.
i dont see any faultsok thank you. i will check if i have any faults as well
I have checked mine and I no longer have your icon!i dont see any faults
mine does... wonder what is it???I have checked mine and I no longer have your icon!
Have you tried contacting Seat Customer care and ask them, if you do and get a answer please let us know.mine does... wonder what is it???
i live in israel and we dont have customer care service... we have the sellers who doesnt know a lot and the garages that probably will not know as well...Have you tried contacting Seat Customer care and ask them, if you do and get a answer please let us know.
i’ve tried. didnt find anything on both sites. i dont even have it in the car manual. is there a possibility to find the new 10 inch multimedia manual?Ok sorry to hear that, We go onto the main UK Seat Website or the by going on Seat connect main web site and find it at the bottom of their page.
