Does anyone know for certain the part number for the tailgate closing button situated on the tailgate itself? I have tried SEAT garages but they can't help.
Its a long story but the answer is still no. I now have the ERWIN wiring diagram and when the weather improves I will trace the wiring. k-electronic ® GmbH are useless they tell me the coding is correct but will help no further.This is your DIY retrofit motorised tailgate you did yourself if my memory serves me right ?. You could try Syphon's suggestion above.
Did you ever get it working ?. Coding was the issue before as I recall.
There is indeed on the right if you prefer not to wiggle your foot if you have the virtual peddle / don't have your keys on you. That button must be just a standard part between the Karoq etc.Thanks for the info. This is one of the schematics I used to get the part numbers. 23 and 24 are the catches to open the boot. No where can I see on any diagram the closing button. I have the 4 pin connector for the button. I may be going mad but I am right in thinking there is a button on the plastic inner tailgate trim?
