Sussed it. Start with it in sync, then use the left hand sliders to adjust the temp and it stays in sync.2. air conditioning, how can i get it so is always on sync? i had this in my last car and once on it was set but I need to press sync every time i raise or lower the temp in the car, again...hope that makes sense
WOW! That is one hell of a mistake. This should be reported. It's a software issue, I am sure Cupra could push out an update that solves this for RHD cars.Sussed it. Start with it in sync, then use the left hand sliders to adjust the temp and it stays in sync.
Think it's because in a left hand drive car that would be the drivers control.
In the UK the driver effectively has the passenger control
Figured this one out, you have to use your own internet connection, I.e. tether your car to your phone for internet radio to work!Another question...might as well hijack the newbie thread ?
Internet radio doesn't seem to work, just sits at loading for ages then returns nothing. Is this a common issue? Not sure if it relates to my lack of updates issue...
Thanks! I'll give mine a day or so and see if it decides to give me any updates, if not I'll check with a dealer.
Thanks for the help!
Didn’t want to start a new post for this minor query, so thought I’d post a quick query here.
Is there a way to reduce cruise control by 1mph rather than 5mph (which appears to be the default on my cruise +\- button)?
It’s quite annoying!!!
Thanks PaulC I was going to ask the same questionHi, when cruise control is on press the set / res button this changes by 1 mph increments
Bizarrely this morning it is working the way you would expect on a RHD car ie from the right hand slider.Sussed it. Start with it in sync, then use the left hand sliders to adjust the temp and it stays in sync.
Maybe they pushed an update?Bizarrely this morning it is working the way you would expect on a RHD car ie from the right hand slider.
The weird world of Cupra software
Ill need to try thatBizarrely this morning it is working the way you would expect on a RHD car ie from the right hand slider.
