rafletcher
529
215
I picked up my Ateca at 6 months and 4k miles old. It was a drizzly day, and I had a 200 mile journey back. Most of the time the auto-wipers were on intermittent. And most of the time, as the sweep started, there would be a squawk from the bldes as thet started up. YEsterday, finally, I replaced them with my favoured Bosch blades and the result was blessed silence as the wipers operated. I was going to change the rear too, for good measure, but I only had a set of blades meant for an Audi A3, and although the fronts came with multiple fixing options, the rear came as a click-in, which is different to the SEAT which required a slide-in as per the fronts. New rear on order from the snappily named Wiperblades.co.uk.
Reactions: Tell
I must do this too. From the word go in the first rain that I drove our new Ateca in last year, the wipers just dragged, juddered and squeaked across the windscreen. The rear is fine though.
Reactions: Tell
Bosch designed the modular ones and the mechanism... I reckon the Altea was the first Seat to get them rather than the usual flappy bit of rubber. They retracted vertical into the pillars. Now all of the modern Seats get the modular design on front and back. I didn't have any problems with them in my Altea keeping with them for 12 years so continued with Bosch for the Ateca (17 years now on Bosch ?). The rear ones are quite common to Seat / Skoda / VW models.
Reactions: Loadmaster748
Are these the ones you bought? They look different to those on my 2020 Ateca.
The Bosch A864s fitted my 2019 Ateca, and work really well, far better than what were on there originally.
Rafletcher has the pre face lifted Cupra Ateca unless they have changed it... research has shown they are the same Bosch blades after FL. A864S fitted on 2020- facelifted as pre facelifted. The Bosch site is a bit useless on this at the minute but Europarts site has same.
Had a thread.?.
Covers front and rear serial number. Note for LHD it's A863S
RHD A864S <- (UK, Ireland, Australia and NZ)
Rear A282H <-
Forgot to mention, the price using wiperblades.co.uk were good at a little under £30 for the front Bosch pair (A864S). Before I orderd them I thought I'd just check Amazon.
Pleased I did - £21 delivered. Can't recall the name of the seller, but if anyone wants to know I'll dig out the receipt.
Reactions: Tell
Obviously you check out the sponsor first.... cough, I got mine from Amazon as well just checking my orders. Been getting them from there for the last 10 years, Altea before ?. Prior to that on trips to Germany when the modular ones as these are use to be very expensive in the UK. That was a Bosch service centre that use to get them in for me, German precision. I'd email and pick them up the next day in Trier.
I only fit Bosch or Valeo blades. OE are cr ap.
The OEM blades are Valeo.
I gave up on Bosch blades years ago. I found that they worked well at first but didn't last very long. I've used Valeo on our cars for years and get about a year and a half out of a set.
I like my Bosch but it might depend on the model. Don't get through many. Altea when I first used turm. That modular design was theirs, motor and assembly where they vanished into the pillar. It's those original non Bosch / OEM ones people generally don't like. The ones that garages try to fit if they need changing :oops:.
I normally used Bosch Aerotwins, but got a good deal on a pair of Valeo Silencio last time around and I have to say they are very good.
Reactions: Tell
I've been using Valeo Silencio for years on all our cars and they seem fine.
Man I'm old! I remember when Champion was the brand to have. Then one day I bought a set of Champion blades and you could see straight away that they'd made them cheaper. The frames were thinner metal and soon bent open and the blades shuddered. Switched to Bosch on the recommendation of a garage.
I used Bosch for years but kept having issues with contamination on the windscreen. A kind of residue that didn't want to come off and made the wipers smear in the rain. Tried loads of things but couldn't get rid of it. Eventually switched to Valeo blades and the problem just went away!
To be honest, I just don't trust Bosch anymore. I know they'll have lots of different divisions making different types of products but I've seen too many examples of them making cheap, poor quality product presented as high quality. About a month ago I bought a 12v Bosch combi-drill for the office and I'm actually angry about how bad it is. I've used full-sized tools from DeWalt, Makita, Milwaukee etc and they're all fine. Even the cheapest DeWalt will take a hammering in an industrial environment. More to the point I own four 12v Makita drills/impact drivers and they are great. The impact drivers are better than 18v DeWalt in some ways.
But this Bosch, it's a piece of ****! It's marked as Bosch Professional but it's barely better than a child's toy. Motor is weak, tiny batteries but still take ages to charge, hammer action is useless. I'm not convinced the function ring does anything at all. It's a pathetic tool similar in quality to maybe the supermarket own-brand rubbish you see for £40
A few years ago my father-in-law bought a new Bosch lawnmower from B&Q. Not long after he bought it he asked me to look at it because it wasn't cutting properly. The entire frame is made of plastic and flexes all over the place. Worst is that the fixed blade is ridiculously thin metal on a plastic bar! It just bends under any kind of pressure so try to cut much more than water cress and it bends out of the way and the damn think won't cut. I've got a forty year old Qualcast that still works and still cuts better.
So I'm very suspicious of Bosch products. I'm not saying they don't make good ones but they are clearly not above selling crap dressed up as quality. You expect that from the Chinese but not a German company. Just look at the Bosch drills on Amazon. They're all over the place. I can count about six different battery types. Looks to me like they're getting cheap crap made in China with their badge on it. I'm not saying it's all crap but I don't trust them. If there is an alternative to Bosch, I'm buying it.
That's the worry of Chinese cars whether they have the soft metal screws on them :unsure:. Twisted quite a few heads off Chinese screws in the past. Routinely change home door handles since the spring breaks. Swap out the Chinese soft mental screws. We do that with the builder as well. He'll look at the screws and say I'll use one of mine.
Reactions: Mr Pig
