Mine is a Cupra Leon but strangely OBDeleven detected it as a regular Leon. As in it showed an image of a regular Leon instead of a Cupra Leon.
I have the pro license and is comfortable to do coding manually if guided to the exact modules to make those changes. Have done a couple that was shared here.
Would definitely appreciate if you can guide me in the right direction.
Find out how to change the comfort turn signal in the control unit 09
light control adaptation.
on my leon the numbers are from 1 to 3 but they are not editable
Little correction
BEEP OF CONFIRMATION ON AND OFF. FOR VOLUMETRIC ALARM ONLY
- Select Central Elettric 09
Select Adaptation
- Select ZV Quittierungen
- Select Quittungston hmi einstellbar
- Set to Active
- Select Quittierungston bei entriegeln
- Set to Active
- Select Quittungs ton bei verriegeln
- Set to Active
TACHOMETER END VALUE
- Select Control Unit 17
- Select Adaptation
- Select tachometer end value
Set to:
- Version 0 = 260km/h
- Version 1 = 300km/h
- Version 2 = 240km/h
EMERGENCY BRAKE SYSTEM (by simoammi)
- Select Module A5 (Driver Assistance)
- Select Long Coding
- Select Emengecy Assist
- Set To EA Variant 4
CUPRA VIEWER and CUPRA STYLE
1/ Adding new views to cockpit
- cupra View on Leon FR
- Select Control unit 17
- Select Adaptation
- Select View Activation
- activate view 8 the others are useless
2/ Adding all view Cupra on display and infotaiment (By simoammi)
- Select Start Screen
- Select Version 2
- Select Lap counter
- Set to Yes
- Select Vehicle variant
- Set to Derivative 6 (if your car is a Sports tourer)
- Set to Derivative 4 (if your car is a Hachback)
- Select Adaptation
- Select Configuration of displayable contents
- Select Engine power
- Set to Active
- Select Engine torque
- Set to Active
- Select G-meter
- Set to Active
- Select Multimedia 5F
- Select Long coding
- Select Car Bodystyle addition
- Set to 1
- Select Vehicle type power stage 2
- Set to Yes
- Select Adaptation
- Select Function configuration hmi
- Select skinning
- Set to 2
- Select Screening
- Set to 1
THIS ACTIVATES A SORT OF TRAVEL ASSIST. TO WORK, THE LANE ASSIST EARLY MUST ALSO BE CODED AND THE ACC MUST BE ACTIVE WITH THE SET SPEED. IT ALSO WORKS UNDER 60 KM/H.
- Select HC Variant
- Set To Variant 1
SCANDINAVIAN DRL (rear lights on with daytime running lights)
- Select Adaptation - Select Daytime running lights
- Select Tagfahrlicht-Dauerfahtlicht aktiviert zusaetzlich standlicht
- Set To Active
ONLY DSG - AUTOMATIC DOOR RELEASE WHEN THE P BUTTON IS PRESSED
- Select Adaptation - Select Zv Autolock
- Select automatic unlock nar
- Set to Active
DEACTIVATES ENGINE IGNITION WITH STEERING WHEEL MOVEMENT
- Select Module 44 (Sterring Assistance)
- Select Engine start through power steering
- Set To Not active
DEACTIVATES ENGINE IGNITION WITH VEHICLE MOVEMENT THAT BEFORE YOU. IF ACC IS ACTIVATED,
THE MOTOR WILL RE-ACTIVATE DESPITE THIS SETTING
- Select Module 13 (Adaptive Cruise Control)
- Select Adaptation
- Select Expanded restart function
- Set To Off
ACTIVATE FOG LIGHTS WITH HIGH BEAM FLASHING
- Select Adaptation
- Select LEUCHTE 12 NL L B45
- Select Lichtfunktion D 12
- Set to Lichthupe
- Select Dimmwert DEF 12
- Set to 100
- Select LEUCHTE 13 NL R B5
- Select Lichtfunktion D 13
- Set to Lichthupe
- Select Dimmwert DEF 13
- Set to 100
ACTIVATE OEM ANTI THIEF ALARM WITH HORN AND DIRECTION INDICATORS (By simoammi)
- Select Adaptation
- Select Diebstahlschutz Schnittstelle
- Select DWA verbaut
- Set to installed
- Select Diebstahlschutz.Modulsoftware
- Select Akustischer Alarm ueber Hupe
- Set to Active
- Select Anti.theft blinkers by inter.door handle activ.
- Set to On
- Select DWA campermode
- Set to Active
- Select Dynamic turn signal control
- Select Theft flashing
- Set to active
OVERTAKING RIGHT PREVENTION
- Select overtaking_right_prevention
- Set to Deactivated
AUTOLOCK DOOR MENU IN MMI
- Select Adaptation
- Select ZV Autolock
- Select ZV Autolock autounlock hmi
- Set to Adjustable
Little correction
- Select Adaptation
Set to:
- Cupra View on Leon FR
- Select Adaptation
- Select Version 2
- Set to Yes
- Set to 1
- Set to Yes
- Select Adaptation
- Select skinning
- Set to 2
- Select Screening
- Set to 1
- Select HC Variant
- Set To Variant 1
SCANDINAVIAN DRL
- Set To Active
- Set to Active
- Set To Not active
- Select Adaptation
- Set To Off
- Select Adaptation
- Set to Lichthupe
- Set to 100
- Set to Lichthupe
- Set to 100
- Select Adaptation
- Set to installed
- Set to Active
- Set to On
- Set to Active
- Set to active
Thank you so much for sharing and making this list. Any chance you can make a post yourself, that will be updated when new discoveries are made and verified? Again thanks alot.
Can someone with a lot of functions activated from stock - ex coming/leaving home, animated taillights, etc - share a full obd backup of their systems, in English please. I'll start comparing with my car and see what I can come up with.
For those without virtual cockpit, I managed to activate "needle staging".
Dashboard 17
Long coding
Staging "yes"
Done.
Reactions: nium and Tell
I only want the light band in the trunk lid to light up in addition to the daytime running lights in the front of the Leon KL. How can I code this in control unit 09? Now the interior lighting and license plate lighting are also on and I don't want that. Anyone know how to code this?
I noticed that the cornering light goes out when the engine stops (mHEV). This is annoying, because usually before sharp turns, where lighting is needed, you need to slow down and let the gas off - and then the engine stops, the light goes out. You put the gas on, the engine starts and the light comes on. Disco!
Is there an option to prevent this?
Yo anybody got an idea to change these values if possible?
- Disable cornering fog lights
Tried Central Elec. (09) Adaptation
--> Leuchte 12/13 NL LB45/RB5
--> Lichtfunktion B12 to nicht aktiv but it still is being activated
- Disable front fog lights when reversing (because why?)
- Use black background for the left and right panels of the virtual cockpit
(same as formentor). They are this weird light blue on the Seat Leon phev
Tried Dashboard Adaptation
--> Display depiction to Version 2 but receive error when attempting to save the value(tried the bonnet open method)
- Dope startup animation somebody posted a video of this
I suspect it only works on a cupra models since the animation starts up in the cupra view
forum.obdeleven.com/post/58632/thread
There should also startups animation on the interior ledlines. I saw it somewhere but didnt flink it.
I tought it was not possible but for some kind of reason when i was cleaning the car and got in the car after a while i saw on the dashboard ledline 2 colors. When ignition/engine came on it came back in one color.
See attached file for the 2 colors.
Somebody saw this and now why?
Finally got my capacitive steering wheel for TA retrofit.
Will install it wednesday. Let's hope it works with manual gearbox :)
Congrats man! I've been looking for a capacitive steering wheel for quite some time now but can't seem to find any, where did you get yours? Btw, would be awesome if you could make a video of the DIY installation, there are many ppl on this forum and others that still dont have 100% clear how to install it (including myself). Enjoy it!
Code all and it works i think. Need only fast changing gears. Mqb you got 1 or 2 sec to change iff longer it shuts off.
Keep us posted
@davidgballester
Here is my manual for removing the steering wheel
  • Manual retrofit Capacitive Steering wheel for Travel assist.pdf
Is there any way of knowing which models come with capacitive from build? The pessimist in me assumes that anything without TA would have standard wheel, but it would be interesting to know if there is certain models/trims which have capacitive fitted but not utilised as TA isn't enabled. In that sense, TA could simply be coded on.
Its only standaard iff ordered and most off the time on the Leon Hybrid standard in the EU
Seems fair. I've just looked up the manual and you can't even spec travel assist with the Mk4 Cupras... Which is strange because my dad's Formentor has it, and I quite like it. You can have PACC in the VZ2+ but not TA.
I bet it would be near impossible to find a Cupra steering wheel with capacitive then. Shame really.
Sorry, I'm no master video editing guy. But I can try to make a walkthrough with photos. dont promesse anything
Keep us posted
@davidgballester
Great guide man! Super clearly explained, thanks ? Just one question though, how does one disconnect the battery? Where is the negative clamp and how is it disconnected?
