Are Mtec C Hook discs directional ?
Compo1
326
87
Hi Lads,
Just got a set of Mtec C Hook Discs for my 184.
Are they directional ? As in do the discs go on one particular side ?
Compo1
326
87
Tell me about it mate.
Wanted to fit them tomorrow i guess ill wait for a reply to my email Monday.
Damo H
4,707
2,816
Car Length In Front
If you have the discs already, (and apologies if you know this already) ignore whatever is cut into the surface, its about the internal veining to dissipate the heat. You should be able to see which way the veins are....
Reactions: kimimaru and Compo1
Compo1
326
87
If you have the discs already, (and apologies if you know this already) ignore whatever is cut into the surface, its about the internal veining to dissipate the heat. You should be bale to see which way the veins are....
Thanks mate the veining appears to be straight. Used a lazer pen to check so their not directional in that sense.
SuperV8
1,840
915
Hi Lads,
Are they exactly the same? If yes - not handed.
Or is the pattern opposite? If yes - handed. Would usually be marked LH & RH somewhere on the OD or tophat?
Reactions: Compo1
SuperV8
1,840
915
That is true - that the major reason to use handed discs is for the improved cooling through the veins, however discs can also be handed by the face slots/grooves etc. More for NVH though rather than performance.
Then you have some OEM's 'looking at you Merc!' who use 1x curved vein disc on BOTH LH and RH sides :banghead2
Reactions: Compo1
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Thats good to know for when i am swearing at them for sending me 2 discs the same
Reactions: SuperV8 and Compo1
Damo H
4,707
2,816
Car Length In Front
We've talked about this before :D And yeah I assumed they would be directional inside.
But yeah agree if the veins are straight then the cut surface may have better orientations.
And remember its not just Merc ;) Very expensive RS6s was what we were talking about last time ;)
SuperV8
1,840
915
You have to go to full fat V8 AMG to get curved vein directional discs - but even some recent AMG's they are 'bean counting' and using 1x directional disc on both sides!!
Vented discs work like centrifugal air pumps (similar to turbo centrifugal compressor), sucking air in at the centre - accelerating is radially and expelling it out the OD vent. Straight veins obviously don't care which way they are spinning. Old turbos used to use straight vein compressors. They figured out curving the veins made these compressors more efficient at pumping air. Same applies to brake discs - but then you need 2 opposing discs to work efficiently. When they use 1x curved vein discs on both sides this is just dumb - if you're not going to the effort of having them handed then just don't bother and use straight veins!
Reactions: Damo H
Compo1
326
87
Got a reply from Mtec this morning.
Thanks for getting in touch.
The C Hook design is non directional.
If there is anything else we can help you with please do let us know.
Kind regards
black_sheep
1,252
587
My RTS performance discs have straight vanes and a similar design to MTEC.
The specialist that fitted them had them on his own Mk7.5 Golf R Estate and I was informed that they were directional (but for the J hook design). Long story short they’ve been fitted in the direction as per the photos below.
Albeit, the AP racing design upon which they’ve been copied has the J hook with the opposite orientation (but these will have directional vanes).
Reactions: Compo1
Compo1
326
87
This gets weirder for me.
Because with the Mtec you can not fit both discs the the J facing towards the front of the car.
With both discs flat on the floor one disc has the J like that and the other has the L that way.
Damo H
4,707
2,816
Car Length In Front
Errr
So they are handed
J will go on left side, L will go on the right side.
So they will face front of car.
Or am I missing something
Reactions: Compo1
black_sheep
1,252
587
Might be worth posting a photo.
I would be inclined to agree with at @Damo H but depending upon which disc is fitted to what side you can change the orientation of the J to an L or vice-versa.
Compo1
326
87
There on the car now. I'll take pics tomorrow and post them i hope im not been totally dumb here :oops:
