Quick google search on images makes it no clearer. Half one way half the other way ?Closed for weekend mate.
Thanks mate the veining appears to be straight. Used a lazer pen to check so their not directional in that sense.If you have the discs already, (and apologies if you know this already) ignore whatever is cut into the surface, its about the internal veining to dissipate the heat. You should be bale to see which way the veins are....
I thought they might beThanks mate the veining appears to be straight. Used a lazer pen to check so their not directional in that sense.
Are they exactly the same? If yes - not handed.Hi Lads,
Just got a set of Mtec C Hook Discs for my 184.
Are they directional ? As in do the discs go on one particular side ?
That is true - that the major reason to use handed discs is for the improved cooling through the veins, however discs can also be handed by the face slots/grooves etc. More for NVH though rather than performance.If you have the discs already, (and apologies if you know this already) ignore whatever is cut into the surface, its about the internal veining to dissipate the heat. You should be bale to see which way the veins are....
Thats good to know for when i am swearing at them for sending me 2 discs the sameThat is true - that the major reason to use handed discs is for the improved cooling through the veins, however discs can also be handed by the face slots/grooves etc. More for NVH though rather than performance.
Then you have some OEM's 'looking at you Merc!' who use 1x curved vein disc on BOTH LH and RH sides![]()
i was wondering on this also, i bought this from audi and they are opposite direction.If you have the discs already, (and apologies if you know this already) ignore whatever is cut into the surface, its about the internal veining to dissipate the heat. You should be bale to see which way the veins are....
We've talked about this beforeThat is true - that the major reason to use handed discs is for the improved cooling through the veins, however discs can also be handed by the face slots/grooves etc. More for NVH though rather than performance.
You have to go to full fat V8 AMG to get curved vein directional discs - but even some recent AMG's they are 'bean counting' and using 1x directional disc on both sides!!Thats good to know for when i am swearing at them for sending me 2 discs the same
Thanks for getting in touch.
The C Hook design is non directional.
If there is anything else we can help you with please do let us know.
Kind regards
ErrrThis gets weirder for me.
Because with the Mtec you can not fit both discs the the J facing towards the front of the car.
With both discs flat on the floor one disc has the J like that and the other has the L that way.
Might be worth posting a photo.This gets weirder for me.
