Leon FR 150 PS brake upgrade to the 184 PS brakes
Matt21
88
11
Kidderminster
I want to upgrade my brakes slightly to the 184 ps model brakes (288mm - 150hp to 312mm - 184hp fronts, 253mm - 150hp to 272mm rears).
Am I right in thinking it's just the caliper carriers that need to be changed to the 184hp model in order to achieve the fitment for this slight upgrade?
BigJase88
Jase
Apr 20, 2008
3,765
1,074
You could well be. I know that was the case on the mk1 leon platform
However cannot confirm either way for the mk3 unfortunately
SuperV8
1,869
940
No, also need the calipers.
Matt21
88
11
Kidderminster
If you compare the rears the orientation of the caliper is also different.
Ahhh I presume that’s to do with the multi link suspension, at this rate I may aswell go with a proper upgrade with some 4 pots or something
SuperV8
1,869
940
Why do you want bigger/heavier brakes?
Matt21
88
11
Kidderminster
Want a bit more bite, fill the wheel out a little bit more and I have a few plans to increase power somewhat so thought a fairly easy bolt on conversion would be a decent idea, how that idea got shattered
SuperV8
1,869
940
The fronts look the simplest bolt on - new carrier and caliper type upgrade. 288 & 312 discs are same height, also same pads - so just bigger disc dia. The calipers between 288 & 312 are different part numbers - I don't know what the physical difference is if any? sometimes it's just a colour?
The rears may be more complicated - the 272 rear discs are 3mm different in height (48 vs 51) - also use completely different pad type, and as mentioned mount in a different position.
Matt21
88
11
Kidderminster
I think I’ll grab some parts for the fronts this weekend and figure out the rears, I’ll get come front carriers on order and see if there is any physical difference because putting my reg and a 184 version into the likes of auto doc, euro car parts etc returns the same caliper number for both so I’ll start with the cheaper option and go from there, thanks for the help, any more findings or advice is appreciated.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
The bite should be good as stock.
When i got a leon mk3 brand new the brakes were very good and sharp so you maybe need a bit of maintenance.
Decent discs and pads and brake fluid change
Reactions: Jay5959
SuperV8
1,869
940
Both TRW and Conti and many other aftermarket brake caliper suppliers have different parts for 312 & 288 calipers. Both have 57mm pistons but the 312 caliper is slightly wider.
I'm 99% sure you'll need a 312 caliper to go with the 312 caliper carrier and disc.
OE part numbers:
312 calipers
8V0615123D Left
8V0615124D Right
288 calipers
8V0615123 Left
8V0615124 Right
You can often find caliper and carrier on ebay from car breakers.
Matt21
88
11
Kidderminster
OE part numbers:
312 calipers
8V0615123D Left
8V0615124D Right
288 calipers
8V0615123 Left
8V0615124 Right
What a legend, thank you very much, I shall be having a look tonight and possibly ordering them today
Reactions: SuperV8
Matt21
88
11
Kidderminster
So I ordered a set of front calipers this evening, I shall update you on the progress whether you’re interested or not, all help has been very appreciated
Reactions: BillyCool
SuperV8
1,869
940
Let us know how you get on.
184 also has alloy knuckles vs 150 which has iron - but I 'think' 'hope' the mounting lugs will be the same.
Matt21
88
11
Kidderminster
Little update, finally arrived today, going to give them a little lick of paint when I get chance which might be this weekend or might not but shall keep up with the updates
Reactions: SuperV8
Matt21
88
11
Kidderminster
any update on the progress?
Sorry dude, life’s been a bit up in the air for a few weeks, these will be painted this year I promise as for when, it could be closer to Christmas when stuff has settled down and more time is available
LeonFR_TDI
10
No worries man, i just started digging into it and couldn't find a conclusive answer, your thread was the most informative so i figured i would ask if you succeed 😄
LeonFR_TDI
10
Did the swap myself, replaced the caliper carriers and the rest was plug and play, no need to replace the calipers 😄
Reactions: Walone
