Yes, it’s a bit rich for me. Not planning on being under the bonnet that often so not really bothered. It’s more the sound dampening issue for me.Looks good, but that price!![]()
Good luck with that one had my VZ3 for a year now still not got a cover ?just collected my new Cupra Formentor 2 Ltr 190.
on inspection at the dealers I noticed the engine didn't look right what it was is there was know engine cover.
I as the dealer to explain.
1. all new 2 Ltr models will have know engine.
2. removed in production they didn't know why.
3. there will be a re-call to add the new engine cover.
they said I will get a re-call vir the App, as anyone else had this happen
So are you saying you have no sound deadening as well as the missing engine cover, as I have the sound proofing, just no cover. I was told the dealer had to remove the cover until the new revised one was available.Yes, it’s a bit rich for me. Not planning on being under the bonnet that often so not really bothered. It’s more the sound dampening issue for me.
Was told this afternoon by my local Cupra dealer to be very careful what you fit, especially if it’s a lease vehicle. Said they wouldn’t them taken off for no reason. Anything you fit may invalidate your warranty and if something goes pear-shaped you may be liable.
Yes. Both missing unfortunatelySo are you saying you have no sound deadening as well as the missing engine cover, as I have the sound proofing, just no cover. I was told the dealer had to remove the cover until the new revised one was available.
Never heard of the sound deadening being removed in the recall.Yes. Both missing unfortunately
Same here with the V2 1.5. engine control cover is there but no sound deadening. Believe this is standard given the size of the engine.I never had sound deadening from new is a 1.5 .
But no issues with engine cover on this model so I have one of those
Sent from my Pixel 6 Pro using Tapatalk
That doesn't sound good, got any pictures ?Just had mine fitted. It couldn’t look any cheaper if they’d tried.
it does a good job on engine noise insulation though, and I think this is its primary purpose although some lettering wouldn't've hurtJust collected from the dealer following cover fit. A bit disappointed if I’m honest, really quite flimsy and cheap feeling
Yeh, thought it should have CUPRA on it at the least.it does a good job on engine noise insulation though, and I think this is its primary purpose although some lettering wouldn't've hurt
