Replacing with genuine Seat 18" wheels and tyres of the correct size for the Leon will just bolt on.I have 17 inch alloys on my seat leon FR 2.0 TDI. I want the better 18 inch ones. If i bought the 18inch alloys of ebay with the tires are they fine to go on or are there other things i need to consider?
It's stating the obvious I know, but you should check your insurance company are OK with it.I have 17 inch alloys on my seat leon FR 2.0 TDI. I want the better 18 inch ones. If i bought the 18inch alloys of ebay with the tires are they fine to go on or are there other things i need to consider?
Agree.It's stating the obvious I know, but you should check your insurance company are OK with it.
Hmm if my leon is stock 17 inch just wandering if its worth it.Replacing with genuine Seat 18" wheels and tyres of the correct size for the Leon will just bolt on.
If aftermarket wheels - you need to do more checking.
Im thinking i leave them at 17 inch but get some custom alloysThe better 18" ones?
Why do you think the 18" alloys are better? Look better?
When I was searching for a 2018 FR in 2019 I tried to find one with the standard 17" wheels, but all had the optional 18s.
I prefer my car when on its winter 17s. Much easy to keep clean and better ride. Can't sense any difference in steering feel, handling or road holding.
As my alloys are 17 inch stock dyu reckon it would just be better to buy 17 inch custom alloys rather than 18 inch FR alloys?Agree.
But generally - as long as you are using OEM alloys and tyre sizes ( as offered for that model of car ) - insurance are ok with it.
Some of the Cupra guys have dropped from 19 to 18.
Because the 18 is listed as a winter wheel / tyre size - the insurance seem ok with it.
If i change to 18 inch alloys thoe i will have to get tires with a smaller wall to keep height of car the sameReplacing with genuine Seat 18" wheels and tyres of the correct size for the Leon will just bolt on.
So my leon has 17 inch alloys. But if i want 18 inch i can just put the 18 inch and theyll bolt in? Im sure if i was to do that id need a tire with a lower profile as stock alloys are 17 inchReplacing with genuine Seat 18" wheels and tyres of the correct size for the Leon will just bolt on.
Yes, you’ll need tyres with a lower profile than your existing tyres to ensure the overall rolling radius of an 18” alloy plus tyre is the same as your existing wheel / tyre set up.So my leon has 17 inch alloys. But if i want 18 inch i can just put the 18 inch and theyll bolt in? Im sure if i was to do that id need a tire with a lower profile as stock alloys are 17 inch
As a couple of us have already said changing from the standard 17" (225/45-17) to 18" (225/40-18) seems to us to make the car worse.Im thinking i leave them at 17 inch but get some custom alloys
Might aswell stick to 17 in that caseYes, you’ll need tyres with a lower profile than your existing tyres to ensure the overall rolling radius of an 18” alloy plus tyre is the same as your existing wheel / tyre set up.
The tyre size that Seat fits to 18” alloys for the mk3 and mk3.5 Leon is 225/40 R18.
Will do that instead rather than getting 18. ThanksAs a couple of us have already said changing from the standard 17" (225/45-17) to 18" (225/40-18) seems to us to make the car worse.
Some opinions are it improves the look of the car but it firms up the ride even more & has little effect on handling, road holding & steering feel. Just choosing different 17" tyres can have far more effect.
