Hello,
I'm trying to add an aftermarket amp and i don't have my own VCDS or OBD11 unit. I’m just after some clarification before I ask someone to do this coding for me.
I've been reading this:
www.seatcupra.net
Does changing Byte 4-7 to FF000000 change an 8RM set up from splitting the front signal between bass/ treble (separate front door woofer and tweeters), ie. output on pins 1 to 8, 9,10,13 and 14 to just pins 1 - 8 in the quadlock (brown block)? I.e. gets rid of the split front/ bass treble signal.
In combination with that, does amending Byte 11 to 00 nullify the internal MIB unit crossover so that full-range signal then goes to each of the 4 signals now routed to pins 1 - 8?
Car is 2018 Leon FR Technology with MIB 2.5 and 8RM speaker set up with no factory amp.
Mk3 2014 Head Unit change.
Ok no problem when ever you have time to have a look. I've realised that it's not same as my current wiring so not sure why I asked about 10,14 pins. Do you think I can get my mib2 std nav unit speaker configuration changed to match my current cars wiring so that othe unit will put bass and...
