MW05
129
14
I've only had it a couple of weeks and this is what i've found...
Interior light doesn't fully switch off when driving. It stays on but very dimly. Is this normal? I pulled up outside home on Monday, locked it up and went back outside to check an hour later and it was still lit up on dim.
If you switch it off it goes off but when on 'normal' setting it dims to what i'd guess to be 2 or 3 volts going through the bulb.
I have auto down when lowering both front windows but no auto up. I live life at such a fast pace i feel i need to raise the windows with a single touch on the switch and feel sad that i have to hold my finger on it.
Is this normal or is something broken? My previous FR PD130 had one touch up AND down.
NO cruise control! My FR had this and i miss it. Would the wiring be in place so i just need to add the stalk and reprogram the ECU?
AC doesn't work but i can get that regassed...
Normally LED lights will stay on slightly if the bulbs have been changed. Check then first!
Reset the windows by holding the switch up or down for 10 seconds after the window has reaches the top or bottom.
If you have the convenience pack on a facelift Cupra you’ll have cruise like I do, otherwise yes it can be retro fitted depending on what convenience module you have.
Thanks for that.
I've checked and disposed of the interior LED bulb. A normal one is now in and works fine.
I've tried holding the switch down and up for ten seconds after the window has opened or closed and it hasn't worked.
Do you know which convenience module i need to refit cruise? Does it depend on what goodies i already have? I have air con and i think that's about it for extras. Frankly i'm a little disappointed in the spec. I thought a Cupra would be loaded.
Here's an update on the lack of auto up and down door windows issue.
Just before Christmas i found every now and then the window wouldn't move when i pressed the switch but would when i pressed it again, or again and again. At first i put this down to me pressing the switch for the rear windows, then i'd realise this car only has two doors.
Well this began to happen a little more often so a week ago i bought a new switch knowing that when it failed it would do so when raining at after i arrived at work.
I have a spare door card and went to take the switch out of that but the switch panel was missing, hence the ebay buy. When the switch came it looked to me that it fitted upwards meaning the door panel would have to come off. So back outside to check the spare and when i picked it up noticed the switch panel, COMPLETE WITH SWITCH was in the door pocket! So it worked out well because i could now see that the switch panel can be removed with door panel in situ and yes, i was right the switch is pushed upwards into the switch panel. All this new info meant the iffy switch in the car was replaced with the old switch and the new one put into the spares stores, which consists of one switch and a rear wheel bearing kit (awaiting fitting)
The surprising news was with the new old switch fitted i now have auto up and down so it looks like the old switch was on it's way out when i bought the car!
