Nov 17, 2023
Hi guys, apologies if this has been put anywhere already but can anyone tell me where to locate the charcoal filter on a MK3 Black edition? I’ve had my purge valve replaced and the fault code P0441 is still coming up, a friend recommended replacing that filter but can’t seem to see it under the bonnet anywhere and google wasn’t much help. TIA
I had this and replaced the EVAP switch (may be a purge valve not sure) with a second hand one and it did not cure it, took it to my garage and they replaced with latest revision new one and that solved the issue.
Check out https://seat.7zap.com/en/e/leon+leon+4/le/2014-754/2/201-201025/ its item no 12 and its housed at the rear of the car
Reactions: Ruhel™
