1.5 tsi reliability
cristian2024
21
7
Hi, found that Kangaroo is related to the exhaust camshaft advance/retard when the engine is cold/when preheating the catalitic converter.
It is because the ea211evo does not have a physical EGR, everything was made with the inlet/exhaust valve overlap in order to decrease NOx.
So don't ask for the usual power remap (with the lambda and timing advance, like all do), ask instead for the exhaust camshaft tweak at low RPM and low driver demand (for less overlap with the inlet).
SSP-253 info there, you can also check by yourself with a tester.
Reactions: mty12345
cristian2024
21
7
attached 1 file with the exhaust retard, sorry for the language
  • Kangaroo-15tsi-dpca-ecu-v1910.pdf
SuperV8
1,869
940
Interesting. This also helps explain why VAG can't magically 'fix' with a software update - as this would effect the emissions homologation which I'm sure they are keen to avoid pushing the boundaries again!
Some cars (Mazda MX5 for example) state in their handbooks - on a cold start, let the engine idle for 10-20 seconds to let the emissions & cold start optimisations settle down - I wonder if this would help the 1.5?
cristian2024
21
7
yes, here(DADA/DPCA) you need to wait 60-70 seconds to heat the catalytic converters.
maybe a new ECU sw release will come soon and will somehow improve the drivability.
if not, a custom remap can fix this.
PS.
personally i also don't like the ACT, is not good for the engine, for sure i will remove it by software just after the warranty ends.
Tester01
143
27
PS.
I wouldn’t bank of any more ecu updates.
Sure VAG has long forgotten about dada and dpca 1.5
Tester01
143
27
Still not got to the bottom of my issues with fuel, but went in for oil change as per schedule and fuel comsumption issues and jerkiness.
Nothing found on their end…Told clutch needs doing…Thankfully I’m not footing the bill.
Said see how fuel is after that but don’t predict there will be any real improvement…And to fill up with Shell over next few tanks.
Waiting for part to come in before it can be done.
Just don’t know why my town mpg is practically the same as me doing a 50 mile
Journey down the motorway.
It’s as though it’s less efficient on a long run than it is on a shorter one.
Its like the engine is working harder then it should be, even at steady speeds on motorway I rarely see 2 cylinder mode kick in for example.
Wouldnt surprise me if this was part of reason previous owner getting rid 😂
cristian2024
21
7
Still not got to the bottom of my issues with fuel, but went in for oil change as per schedule and fuel consumption issues and jerkiness.
It is related to valve overlap (emulating EGR, for NOx decrease) and also on injection (to less fuel for a wall guided injection).
The kangaroo will NEVER be fix 100%, this is the wall guided disadvantage: at low RPM and low engine temperature not all the fuel mixture is reaching in the spark area to ignite properly.
A partial fix can be to small increase the fuel when the engine is cold, but not too much because the fuel can reach the cylinder wall and get to the oil.
Kangaroo problem is not related to fuel type.
DADA and DPCA can run with 91,95,98 fuel.
If the fuel is not good then the ECU receive the detonation info and will auto modify the spark advance
- you loose some power (but only on full throttle you will feel this).
That why you get ~175hp and ~300Nm on stage 1, because the tuner increase the spark advance and you are forced to use 98 gas.
Tester01
143
27
Thanks but wasn’t kangaroo jerk I went in for.
My DSG in general is jerky.
Thanks for that keep it in mind if I ever get a stage 1
Glosphil
487
221
Gloucestershire
PS.
Why do you think ACT not good for the engine?
Glosphil
487
221
Gloucestershire
At a steady 70/75 on flat or downhill motorways the ACT regularly operates on my 1.4TSi.
cristian2024
21
7
because of vibrations that will slowly kill the double-mass flywheel
i don't like the switch between the normal-ACT-normal -- is not smooth
also don't like the sound -is like a bike, especially on engine brake
those 2 cylinders are working at the knock limit in order to compensate the torque demand from the driver pedal
also the other 2 cylinders that are deactivated are cooled down, operating at oil temperature
the max economy is 0.4L/100km (as officially advertised), so ACT is just a bad joke (my personal opinion).
Tester01
143
27
On motorway,
Only notice when I lift my foot off the gas and I’m slowing down or breaking.
Even when I’m being gentle on the throttle to just maintain 70mph, rarely see eco flash up.
Cruise control around 70 same no eco all cylinders firing
'& Son' managed
Third Party
Mar 2, 2018
270
89
South Coast
The transition between ACT coming in and out again is seamless on my Golf 1.5 DADA - and to
be clear it also operated like this before the remap. It seems to work well and predictably, so I've
never had cause to have an issue with it.
cristian2024
21
7
I think i found how to force a delay in ACT activation
cristian2024
21
7
==catalyst heating (first 2-3 min after cold start) - kangaroo
-see spark retard - to generate more temperature
-FR commanded 14.63 but at the lambda probe is 14.87 because of exhaust camshaft overlapping with the intake one(scavenging) in order to have more oxigen to burn and heat the catalyst.
See above picture: "The torque-based control automatically compensates for this loss by prescribing higher cylinder-charge densities."
==And this is the trick that WV was using to try to fix the kangaroo and still not working :)
== catalyst has now the normal temperature, back to idle rpm, kangaroo not present.
-because the engine is allowed to run efficiently
-perfect lambda 16.64
-correct spark advance
-inlet/exhaust valves are not overlapping
SuperV8
1,869
940
Interesting - but as this is all to do with trying to reduce emissions and has been homologated - VAG will never touch this as it would need new emissions homologation testing.
cristian2024
21
7
i still hope that you are wrong and they will come up with a fix :)
Tester01
143
27
I feel VAG have moved on from this engine, well the earlier variants at least.
But once can hope!
Anybody know where the throttle body is located on the 1.5 TSIs? As in is it under the air box for example or more under the intake
Checked the workshop manual bit confusing.
Thinking maybe to inspect the throttle body and give it a clean if necessary
