ExiledWeegie
122
71
Fife, Scotland
well today I installed another timing belt kit and waterpump, this time from Febi, the same noise is still there so it clearly wasnt the Gates kit causing it, Ive took the aux belt off and the noise doesnt change so its deffo coming from the timing belt componants, very annoying, its bang on timing and drives perfectly, could it just be a bedding in thing with the new tensioner and roller? I havent done timing belts on these cars before so I dont know if this is normal. although I did find this and and in the comments the guy says its better after a few miles. its exactly the same noise mine makes with the Gates or Febi kit....
also wired in cruise control today and all works good :)
Battoussai
548
194
Portugal
Couldn't that be a bearing on its way down?
Reactions: ExiledWeegie
ExiledWeegie
122
71
Fife, Scotland
its 2 brand new kits installed and both make the same noise all parts changed each time, tensioner, roller pulley, waterpump and belt, everything torqued to spec so I cant see how a bearing could be responsible in both kits unless ive been crazy unlucky lol
bruceR
2,578
665
Monifieth, Dundee
Maybe not a bearing from any of the kits tho, maybe something else
bruceR
2,578
665
Monifieth, Dundee
Cleaned out EGR and cooler pipe - not as bad as I was expecting but what a PITA for access, my hand and forearm are aching
Battoussai
548
194
Portugal
Doesn't your engine have 2 idler pulleys?
ExiledWeegie
122
71
Fife, Scotland
no thats a different setup to mine, mines the 1.8t 20v AUQ engine, it has the cam pulley, hydraulic tensioner with idler pulley attached, then it has a concentric pulley that helps keep belt tensioned with the hydraulic pulley, waterpump and the crank pulley, nothing else. Ive made a thread for this issue to save cluttering up this one, appreciative of any help.
Reactions: BadBoy03
iammooks
1,827
1,228
Did you replace the o-ring?
ExiledWeegie
122
71
Fife, Scotland
anyone breaking a cupra and have the drivers door inner handle and cable? my cable snapped today and in the process of trying to fix i snapped a tab off the but that the cable hooks onto :(
Reactions: Manic172
