Leon PHEV - EV coolant refill
adrianator
118
42
Did anyone get a warning about EV coolant being low? I got it and it is indeed low. I checked it but there are no signs of leaks.
According to the manual, it should be refilled with G12evo which is the same coolant that the IC engine uses. The manual is also mentionenting in bold that i shouldn't top up the coolant and go immediately to a specialised workshop.
But now the question is...why is there a security seal on the EV coolant tank? Whatever safety reasons they think they got can be applied on the coolant used by the IC engine which is missing that seal.
I don't want to put the car on platform and send it to the service for a fluid refill, it's kinda stupid.
Also had this warning light on and off recently with my Cupra Formentor PHEV. EV coolant is just below the minimum.
I can't see why there is a security seal and I am reluctant to take it to a dealership for a simple top up. Hoping someone could shed light on why there is a seal?
adrianator
118
42
So I searched for an answer. That coolant goes to the batteries and if there is a leak there, the liquid will have a pretty high charge and you can die if you touch it.
But for the moment, I fixed it by removing the hose where the seal is located. After I removed it, a lot of pressured air came out and the coolant was back to normal. That's weird but it worked...for now. I'll keep monitoring it
SRGTD
2,745
1,605
Presumably if the security / tamper proof seal is removed by any one other than the Seat dealership and there’s no record on the car’s digital service record that the EV coolant has been topped up by a dealer, then it would give Seat an excuse to decline any subsequent warranty claims in relation to the EV cooling system.
I'm assuming that if a dealer does top up the EV system, then they would fit a new replacement security / tamper proof seal?
C_ED_99
263
28
They'd probably void the warranty on the battery too if the cooling system wasn't maintaining it at the correct temperatures 😞
Apr 22, 2024
Hi, I'm facing this exact issue right now and found your post via Google.
To get rid of the pressure I also removed the hose and the pressure and the liquid came came back.
Has this problem reoccurred for you after this? And if so how did you solve it permanently?
I would appreciate it very much if you could reply back, since this is the only post I found regarding this issue.
Thank you!
adrianator
118
42
Thank you!
Hi,
Since I made that post with the "fix", I haven't encountered this issue. Everything worked fine. No other issues with the car, battery or drop in coolant level.
And...sorry, but I don't have any other information about this. I wanted to ask the people at the service but...let's just say I avoided this subject of removing the hose until the warranty runs out.
Jul 4, 2024
7
Hello.
There is any risk of it spilling out coolant when getting the hose off? My leon has the same problem, the first time the dealer topped it up but they charge around 25€ just to fill 100ml 😅...
Apr 17, 2025
Hello.
Hey, I noticed my coolant was below min so I undid the hose to release pressure. Turns out there was no pressure and when I disconnected the hose some coolant leaked out so I put it back on v quickly. Did you ever get to the bottom of your issue? Mine is a well below min but no warning. Thanks
adrianator
118
42
Some people say that if there's no pressure, then the coolant is leaking somewhere. Not trying to scare you but the worst case scenario is leaking in/around the batteries. Either way, I have no other data to back up my claim, just people's comments around the internet.
For me, since I disconnected the hose and plugged it back again, I had no issue. And it's been 1.5 years since I did it.
Apr 17, 2025
Thanks i appreciate the response. I'll keep an eye on it. Did some coolant come out of the hose. Some did for me and I'm not sure if that is normal.
Jul 8, 2025
Had this same issue come up today, hadn't looked into it before I went to sort it myself, stupidly yolo'd and cut the security tag off and undid the reservoir lid partially, and it started venting pressure, and the fluid level started to rise on its own, closed it back up and its been fine since then. Need to monitor it.
Odd thing is I had a local garage service it, as the main dealer wanted an arm & a leg & a kidney to service it (it's out of warranty now), they supposedly checked the antifreeze levels in the coolant but not sure how with the seal on there‽‽‽!!!
adrianator
118
42
Same happened to me. Same behavior but I disconnected the hose.
MJ
5,619
54
Manchester
FYI: If there is unusual behaviour on your vehicle and it concerns the HV coolant level being low, it's generally the sign of there being an underlying issue, especially when there is a lot of pressure there, there should be next to no pressure.
Jul 4, 2024
7
Hello.
The first time it happened I just went to shop and they supposedly reffilled it. The second time it started to lower I just kept an eye on it and it stopped between the max and min and stood there until now. However when reported to shop they could find any issue or explanation to that.
