EML but no Engine Faults
Dec 1, 2024
Hi All,
I have a 2008 6L ibiza, which has the EML on only (no EPC). after connecting with OBDeleven, I have scanned for fault codes and there are no engine fault codes, and I include a copy of the scan below. There are no other warning lights on at all.
I tried to clear the fault codes but when trying to clear the Airbag fault it comes up with a communication error. I wonder if the airbag control module is faulty and it's causing the EML? Does anyone have any ideas how I can resolve this?
OBDeleven data log
Date: 2024-12-01 15:37
VIN: VSSZZZ6LZ8R174840
Car: Seat Ibiza
Year: 2008
Body type: 3-dr hatchback
Mileage: 249680 KM
01 Engine
System description: MARELLI 4MV G 5953
Software number: 036906034DG
Coding: 00071
Trouble codes:
No trouble codes found
02 Transmission
Trouble codes:
03 Brakes
System description: ABS 8.0 front H05
Software number: 6Q0907379AF
Software version: 0002
Hardware number: 6Q0907379AF
Serial number: 00000000000000
Coding: 0002181
Trouble codes:
08 Air Conditioning
System description: CLIMAtronic PQ24
Software number: 6L0820043E
Software version: 3805
Trouble codes:
00705 - Relay for coolant fan, level 1 Open circuit/short circuit to ground
static
09 Central Electrics
System description: 000B BN-SG. 2S36
Software number: 6Q1937049F
Coding: 24716
Trouble codes:
15 Airbag
System description: 03 AIRBAG VW5 0010
Software number: 6Q0909605AD
Coding: 12339
Trouble codes:
00532 - Supply voltage Signal too low
Intermittent
17 Dashboard
System description: KOMBIINSTRUMENT AGD V04
Software number: 6L0920903C
Coding: 00405
Trouble codes:
19 Gateway
System description: 0305 GATEWAY CAN 2S36
Software number: 6N0909901
Coding: 00014
Trouble codes:
25 Immobilizer
System description: IMMOBILIZER AGD V04
Coding: 00405
Trouble codes:
37 Navigation
Trouble codes:
44 Steering Assistance
System description: LenkhilfeTRW V272
Software number: 6R0423156
Coding: 10111
Trouble codes:
46 Comfort System
System description: Komfortgerát 0002
Software number: 6Q0959433E
Coding: 00016
Trouble codes:
55 Headlight Regulation
Trouble codes:
56 Radio
Trouble codes:
Dec 1, 2024
well that fault has been there for a few months with no EML or any problems. I also replaced the relay to no avail.its only the last 3 days that the error has come on with nothing different
