nd-photo.nl
5,207
1,111
The Netherlands
youtube.com
Hi all, it's been a while, but I am back to Seat after having driven some other cars in the meantime.
Short introduction: My name is Andy, and I just bought a Seat Leon Mk3 ST Cupra 280. My goal is to have a Stage 2+ car, and I will be documenting hopefully everything along the way. I hope to share some knowledge along the way, as the MQB platform is pretty new to me.
Car history (worth mentioning)
2012: I bought a yellow Seat Leon Cupra 1M 1.8T 20VT, which had many upgrades which took it from 180BHP to 261BHP 395Nm (Stage 2). Learned a lot from the car and was my first real project. Album: https://flickr.com/photos/andyramdin/albums/72157629066602690/
2015: Renault Clio RS Phase 1: https://flickr.com/photos/andyramdin/albums/72157650112492783
2018: Volvo S80 2.4T (5 cilinder turbo): https://flickr.com/photos/andyramdin/albums/72157694648668714
2020: Mini Cooper S John Cooper Works. A bucket list car, I wanted to experience this pocket rocket with the 4 cilinder supercharged engine: https://flickr.com/photos/andyramdin/albums/72157714537601506
2022: Mercedes CLS55 AMG W219. Also a bucket list car, as I wanted to drive a big powerful V8. The CLS55 has the supercharged (kompressor) M113k V8 engine, which is considered one of the best Mercedes engines. Album: https://photos.app.goo.gl/6SP5PFAUXCqanoSX9 . Build thread: https://mbworld.org/forums/c219/844341-nd-photo-nl-s-2005-cls55-build-thread.html
AP1GczOlkfyga9v_feJcL8FTLmDZ12X2Ngv-Gg7R3zZ3ePXsuHCpwVRhdnP9BQ7SICSNOEMjIEVlK8fEghtjkPq0NAz4QJ7NEYk66ge73k-BfDJO2a0RwQdbqOUo2zYRKOJ4qVHfwKdeKyaKxxCrhnon1Za3-g=w1920-h1281-s-no
AP1GczMWKfLoIQgpVyIe9Nl5MpBbHZxbK27zln9jVNJ-HEoOOTyd72PP4TW6YOiVPXQLAp8j1UdI8D5J6_-4WbZzzB_z0wthIIib-Coh_LqdH8xw9rmhMuHnfqcEIZyVSAb6Q3SV3A4Cth2EhONmLj2WZ1XmtA=w1920-h1281-s-no
2024: I sold the Mercedes on a friday and on that sunday, I drove home in this. A 99% stock Seat Leon Mk3 ST Cupra 280 in Dynamic Grey with only a cutout valve.
AP1GczPW3bQXT_mna6bkN-3tUW_a-avhbatjFT5wRZelq6kAqYSJ_iHyWjW5ad5K4oefodIrhij2fjHi0soxpyzsOvVAcEvg2DshD5vYCeWu6GqaD4_FTw4sH_pGls4ISN21BpWm2x8s85I3W6gz_2RyZosVbw=w1920-h1080-s-no
AP1GczNLig3yDrPXhNrGmTHLJ2ZRV7Ooco6Gy0r5-6_9UaFKOb9fdwoYAZ_K7FLINaGW_sBX9MEEmxwTHAnRuW_9fyWGPXl1OP6jLity2AsdxBf-UBFhBxulRpTC61m5FD6wM_bMiWO7ci7zwpHpw1napcoN1Q=w1920-h1080-s-no
Plans & progress:
Engine
- Remove Silica bag done!
- New revision fuel hose 06K133986EB done!
- New fuel hose MPI injection 06K133986K done!
- New PCV valve done!
- GFB DV+ T9381 upgrade done!
- Turbo Elbow upgrade done!
- Siliconen Intake hose done!
- Turbo Muffler Delete done!
- Remove Airbox Snowguard done!
- New airfilter done!
- Oil Service 11-12-2024 done!
- New Nissens Coolant Expansion Tank done!
- Homemade Air Deflectors done!
- Homemade Air Deflectors painted done!
- Air Intake Snorkel Modification done!
- Heat Reflective Tape Intake Hose done!
- New Bosch spark plugs done!
- New MAP sensor done!
- New Oil cap done!
- Budget 3.5" Air Intake done!
- PCV Hose Fix done!
- Bartek Upgrade DSG cooler (fail) done!
- Billet Coolant Nipple done!
- Velocity Stack Air Filter done!
- Big Purple Air Filter done!
- New Camshaft Position Sensor done!
- New Serpentine belt tensioner done!
- New Serpentine belt tensioner (nr 2) done!
- New Serpentine belt done!
- Coil Pack Negative Terminal Wire Harness done!
- Pikey R600 Intake Modification done!
- Forge Turbo Blanket done!
- Intake Beauty Cover done!
- Big Velocity Stack Air Filter done!
- New Oil Pressure Regulation valve done!
- New Hella Low Pressure Fuel Pump (LPFP) done!
- RamAir Oversized Intake PRK-148-BK done!
- New Coil Packs done!
- New Camshaft Magnet Actuators done!
- Coil Pack Earth Wire modification done!
- New Oil Filter Housing gaskets
Drivetrain
- DSG Oil Filter Service 06-12-2024 done!
- VCDS Starting Vibration Reduction Normal done!
- VCDS Starting Vibration Reduction disabled done!
- DSG Oil service 17-08-2025 + Billet Filter Housing done!
- Differential Oil Service
First looks under the bonnet
AP1GczMkhvu9als3qT9AP1cL2wOf7CToq1npEvpRAZlQGquftAzVbNlzbfmbL43caI--Mmn6qbe8WbbccnUaO7qMjI2uWKNK-iRtJZjyD8REGS3gOFv03yvSdIEBNN25A7p4_WZYVRIyhnO-FTNdjcUXxUGfOg=w1920-h1080-s-no
Stock IS38 turbo
AP1GczNxT59B5FC4le26h0U3LUKZEEg_c9pKdaq44qj594vb_PwWA5m2YjFeDnFFyxKrwU2FrpLO18akpaS9exnROGYN2GAo8sIqjNWzcnMmnOKOGmcYnoTKnw_UsuXHrLCMkVv8OgDH1SCxbsObr_tBoBm3Qw=w1920-h1080-s-no
Banner battery
AP1GczMIA4xD8VW4hPZosPVw4XotXYZ1bWgYUXtCNHJO4O-zSthc5ghvcY1SKwA0hcGcBHnaukiNRJkXieIkfv_MqV_bnNQZWi6idvlzq_8zK69QfiW5CPzLD5cZUe2tVC_ZxN5Q0BhU6ulQX9TkSq1RVQQQgQ=w1920-h1080-s-no
Stock downpipe, some oil residue aorund the oil filler cap
AP1GczPCk6gL3GlwC8i8jrALSy3BlwQqxQrscxDeKLQVapchCZf-Xd0oVvPQUmLxBxHMFYShcMquT4AevTW-9Bv3AYPfMFCF2bKPB2fthrYTLcodb8HKaS4aprF0PApnLVI38bpdmJhh5mKBcbrg9cy4NO13oQ=w1920-h1080-s-no
The G13 coolant reservoir with the silicat bag
AP1GczMoEC1CXkC5xQlyiPTFWNPpXbEdsb9aAIplaK47mb7Og145WAIEvksHaVKqK7EMJ9kjA_12WzPQh_6p4iseO-kj1Fo9bwJ8LiMnx-BnzcijaNjQvoCy2ew4jI8En6OcwcRSKr24AdQhBUU_tEMHPKeoeQ=w1920-h1080-s-no
Solenoid for the exhaust cut out valve. I will be replacing this with a separate vacuum pump, as I dont like tampering with the original vacuum lines. This is tapped from the brake booster hose
AP1GczPfWxxV-Fa-pj_pfaOWgH96ufBwSz0To8rMKYiM8CyzjIi6RYqZ5VZVnKpviJWs6dveFoAJB3JV1xp3gmDGbbciKNIjDsKYM9ZItLQ9K2lBRnnafr2jX_P5cXSFfA10gz0nsbHjQlbk9mp9ZhQjTPkrdw=w1920-h1080-s-no
Love the 280 they are great motors and have lots of room for extra everything and the Mk1 looked very nice, always wanted one of them.
Couple thoughts
Are you planning on replacing the engine / gearbox mounts or did I miss that in your list of things you have / want to do
Are you planning any coding changes to your car as again there is a lot of stuff you can turn on / change on these motors.
Have you looked at SuperPro TRC5000 (if you want a bit of offset, I also personally fitted the Audi Front sub frame as its stronger than the 280 Stock item and not as heavy.
Other items I have fitted (not saying I am right but things to think about) Front Strut brace, I replaced the front and back stock brace items with Leyo ones (much bigger and stronger), Catch Can, upgraded low pressure fuel pump along with the HPFP and Super Pro ALOY0018K Control Arm Lower assembly.
Now i have done lots more but these are the things I first fitted when I upgraded from Stage one.
If you are finding that you are getting very high temps in the DSG Box you can buy upgraded aux radiator that solves that issue.
Looking forward to reading your journey, I am still on mine as they keep finding new stuff for me to spend the cash I dont have on :)
Thank you for your message! This is my daily car and I have become a little older since my 1M days haha (I'm 42 btw)
:p I want the Cupra to stay comfortable yet sporty. For instance, I want to be able to have a conversation without the exhaust note being "too much".
Also the ride should be comfortable yet assuring when driving it hard every now and then. I wont be doing any trackdays, I'm not that good of a driver, and again, its my daily. I was also looking at the Performance Pack, but I have some friends with Cupra's and they all had the same issue with warping brake discs. Even though I love the look of the Brembo calipers and the bigger discs, I stayed away from it.
On the CLS55 I performed a nice brake upgrade, from 360mm single piece to 390mm 2 piece discs using Epytec brackets. This allowed me to use the stock 8 pots AMG calipers.
AP1GczPMdT1KeW5kMyfe7CwdxfTi1w3dkv4gfM9peWwHTVAt2uIIadD5AnQtk4-pcPFi4KjuKpT42m1mVuqZaBr900KkAwgCoep4CtsbG2U1xtNvCXLD7DVLTt8b3R_Q3KTPLLJRxJg0xKp7kr1j3iu243nUyw=w1920-h1080-s-no
AP1GczNH0fd5LNK2luhITxN6G8n-A-TYgT7GDyt_hD0lPtUySTi29v7MvodYwCj5L0tzeDzBkZQ19b2XmxN94I6P8C4aog2XcKcgvTXRGnZN2_bYaF80eWFq1cdMbmaKnEU2s3_cKNI_nA6f61xp1lKPL7tJNQ=w1920-h1080-s-no
I can do a lot of work myself, having a mid rise scissor lift was a good investment :cool:
Reactions: tracktoy
First addition, a battery monitor. I can highly recommend this, as it allows you to monitor your car battery using a bluetooth dongle. I stumbled upon this when I was chasing a power drain on the Mercedes CLS55. A great addition for about 25 euro
AP1GczOP1YtbHVc94hGuOFaOlnnOaBx24PUv2CgRLjw5gf0-Din_o4OQ2Jrr81kt_DpXiTiDl09OXC-zWsH1RGfR6sECSGXvKmdL9w66_ra2yEik4njFB1CvuAjcmFBKWWVjFTq7MqkSNdlgpVk08Sn2EFgB-g=w1920-h1080-s-no
AP1GczN5Ub1juV2heE3uaSFnoOStLDk2DxzuNL9DY508WtquglYik2uqtmUU75Vv53zVI5aDOMm4raK0nkHb-0D1aP6xmtAqff-eVy4cIjtG8YflEWdFzAY37c9KQXTnYxdin61s0eSdrmAkB49F5xAifpn7Ag=w1920-h1080-s-no
Silica bag removed from the coolant reservoir. My waterpump has already been replaced and they filled it with G12 Evo instead of G13. As you might now know, G12 Evo contains silica and thus does not rely on the bags anymore. On the dutch Seat forum, we had a couple of members with blocked heatercores by the bags rupturing and clogging the heatercore as a result...
This was quite hard to do, as the bag does not want to comply. Please keep in mind, that reservoirs exist where you cannot remove the bag (!).
AP1GczOWp6YP9v7-xBxlzOosmPDtehT3WN1tKiZpjkob_sQK48Ms53-blf77l72IK3IA1hSkYxI83ZhtcH3IK47SKAhtBQ9kF7cf34momkNIHDYAQSieotp1k712IXXCi5MGEh9pZCcVi-5QSzW5jy75OFBEBQ=w1920-h1080-s-no
AP1GczMJJM7xEK2OY9Q97-WGzwJt3mka48Bu-iELSR1MDdi9iSC8ZlnPSWZ9hjQ_YUImTy8jO9Ba9FjFErVIlRsvHzSyHwRGWF9v1iFpKg3AHbeTP1gQcU7VUS9ExjiPkpAcf6gNkisqbcqBdgB5IMTOn_RtZA=w1920-h1080-s-no
Upgraded the indicator bulbs to Hyperflash amber LEDs. I dont have the full led taillights, but that means I get to choose my bulbs :ROFLMAO: As the indictor part on the cluster is quite small, I went with the brightest you can get (y)
AP1GczMEHQ7iNTjuqDfXmcx7dFw5bqe8YPSJ1OflrBy8lActYBxXi5eYIZDXDwxpuf5IGjHes9mYWK8MWS7jOfn7qq6Vgt0YldIWYkcFoUjsDG-sftW73VRF6TVjXXVlZ4cymwiVwIMBNszrt4sx9WE3V6EAQQ=w1920-h1080-s-no
AP1GczPUC5PrdiW7_ALAKMdeiCw7Bz43rR1tnSxRiiCMlqw2sm5_I4lr5ACjIzQFcFgYaScwSQC2XLhhS9Lk02ioZKku8yKQ4Njz8GjP5hnRucThM4kHY-ZJWUqOivn6lTy4BwiaFVxwJ_e4KGovoLu1GaTQbw=w1920-h1080-s-no
AP1GczNETxzmEMbVBsv1W71CfIRutYiLBxHIgeivfrgm_mk3jpekcg8fQ2_G9gzokfwKru764UntZ1TechGfmxvTRmHX965B-Rco5HHkv0AmJ_3KJU5NviUiZXkJOlsD1EfrDztS151MWOQajHwoHYj-ZmLqRA=w1920-h1080-s-no
I highly recommend checking and replacing this fuel hose as it is known to disintegrate and cause havoc. This is applicable to all 2.0T lumps, at least before 2018. Its easily recognizable as it consists of 2 pieces which are joined at the front of the engine. If the joint is not there, you are good.
Fuel hose: 06K133986HF
Optional: MPI fuel hose 06K133986K
AP1GczPvnnMThFbWChv-2Wp_cwg2kjoq_m_kG1HWrqYbik58HvfcnT2O_6ULE4PWk2V91YOCIoygCtRKAK7iTjNHuOptDumPp4-qoiSxn-Z4QgQIE72p9hs1wJUjycj7unNZsDWRYv91gzASg2i4ENSTLW16lQ=w1560-h878-s-no-gm
AP1GczM1IFLsB_z9cvzXqu4nwG_BRzLyxVF3tTZ3ontHW0FKiRZCAjuoFZOSowCduCGak72_qSMhipZBTsEl4da2oMosSqELUMjWh3XVnObnWd6WPTdbs-fRSBs2mpdfwpBZPJ6z2bvzBD4JgVnkjCtTJVWqfw=w1560-h878-s-no-gm
MPI fuel hose
AP1GczMO1MVTFmhBQLuSnCVqyvrMFAfeWjSZdCnrpQf98uBSz25PIt6-Z_nBXhm7uzjFF-H_lQBjKWwBdP_-5WBzTOFZcPvmvLuV1izKhzru9Pteubd2b-Dsaso5HzPJgr9GO9PpUuPGaii6_itZIjWrMvmRug=w1560-h878-s-no-gm
Old revision fuel hose (see the joint close to the oil filter housing)
AP1GczODF3se6FItuvU5hsCGhNOd15WyOErVn3xG0O4EYAFlXHMplEyj4f-fIs1OcdZf_OHAZSBMPXwvNgoP3yrIYQUvV71HFUnNBSZ9jhcPc_yV053J0K5SDkb7YXNudJcLYFgdekTcKUmUkR0Isec_ObZYxw=w1560-h878-s-no-gm
Closer picture
AP1GczN_thhriuX5OtEyfyFI_LYJZSdL8k1D7i2FBRO9210M8V43fIHycsYe-lFOKzBwb3M4EVYTsgiV9MoLMMMrNUMVVXibDxxtd_OEyOugIS3ns9hNRiBZKDGgEMBZs35_sAHETnIGBtHRGNDmsI-opvcezA=w1560-h878-s-no-gm
On the right side of the HPFP is the connection for the MPI fuel hose
AP1GczNocy1q_3KY9MJzOIj6I1RFeDgFauS58i43ON9TfGE8wZLvLLEghUM-74kRhtYNPOSdwFnYurg51LvZy9ZOW2fHNyR7Mr3B4Z5saEP1AvjcvTLi5WAXRilIhWAArazlw_3Bf4y2KqXSW00a0u2S4YbNFg=w1560-h878-s-no-gm
Pro tip, destroy this and buy a new one when you mount the new fuel hose
Partnr: 06K133184A
AP1GczMDTB5yxZhf0iKyP_g8MIU5HrkEOQaQEKRESV8J451sb_6jYBBTd1dJEeNERKNwF3B-4L5P7IUhu_pqbv5Lj2-VwnTK8x5X_oUE1N0K_ODMaIPWsLpDRUcTR5sAT2lhR5G6GjLpedyg1W8M6c1bTCQUfg=w1560-h878-s-no-gm
AP1GczOLMyVlYEE8MwTX4qEuAaXgyn0GdOlYPa36MrIEvyJeoNspeMcUpkn0Ase7t_hqSXUealuTiJI1DSPclhQGrG6SnXaZqiQ4Lh1LYlfkzUIbUPudVR5bn86I9ZDaTymocqj5D3xg4w-PYPt9UR40td49Qg=w1560-h878-s-no-gm
New hose in place. As you can clearly see, it consists of one piece
AP1GczPTJZ4Lpewo_tpMOiGCiZl3YJNsx1jtrQLGw2pkeAxyppaZct0d3VImoKAl_CBvm2_bri6_nhCddua4Ep_SSAJWV3tlI9v4UKo3ApbPR968Xwq1l_3MMrIEo2i3n14sXKUIgQIk6ysLg1qsM1LcAlnxSQ=w1560-h878-s-no-gm
AP1GczPRyLpEQCzkFNrWC0mIlakmBgmP1p5JQIiQLh5VpFKpUjtQVSrpnruvaIKmtytrV5bZFvMSGKsLVrgCcCDfoXLL94ucsOueX1Jbz4uftAzMSSyVwk6mErnNrWsmr5V3oYT1NSSUTcEdU8j7xFUik_E9Lg=w1560-h878-s-no-gm
New MPI fuel hose also in place
AP1GczOFwJmMJSgB_bPg1swcTKm-7Ipz3WnbfEJf3KXi_cRa86g43ZR0CNubFRX2g00MtDlcGagxGjyEG6Yve0UMjewqjinakC56ZY5hg_CqRqocHVoFbVUTOecGlzmX3Q9JJxOAYko9tjJnPEJcxYcvbToQvQ=w1560-h878-s-no-gm
AP1GczMy0JJA4IN_MsGSeyFGqklICGLwHL1_JY8CoEmoMesr_D0sZVuwzFTzjmkz0_20270CFccFJH-6aGPonJbwkPxKoix_bmVjZTcG16E2okgK7vl2X3ziHjBT0IAPOzJBKR0_b0HsJK3pQKjogKia6S311Q=w1560-h878-s-no-gm
