Blind spot detection
witek_77
123
55
PL
You need SW 1040
but the only thing I will gain from the new software is showing arrows in the main view or what? because the assistant works well, changes lanes nicely.
Yes
witek_77
123
55
PL
Do you have vcp or OdXX E?
I I also always try to do everything 100% and as the factory wanted. Here I have everything coded except for this. I have godiag passthru heads, I have free vc tool and I have odis E but in the hmm "educational" version. I have never done anything with these programs. I have always used vcds for older cars and now obd11. to upgrade the camera and remove the CP I had to drive 35km and pay.
witek_77
123
55
PL
You Change Kamera? Why not Flash?
No. Firmware only on cam. CP was from blind spot radars (i have used one). I have soft with G now
witek_77
123
55
PL
I suppose the most important thing is the blind spot and the camera. When the blind spot detects a car, the ability to change lanes is disabled. The parking sensors probably have too short a range. If I ever have someone upgrade my 44 controller to 1040, I'll let you know. For now, I'm glad it works on the small/left screen because that's what I use anyway. But i have 12pdc so im not objective
witek_77
123
55
PL
strange because it is he (BS) who does not let me turn into the left lane. but I will not argue. maybe he uses the blind spot only when it is there, but it is not required. he does not always let me turn into the right lane either. I have to have a large distance between the front and rear cars in the right lane.
cairus
1,575
552
is correct and logical for me. He needs the space as a reserve if the process is aborted and the system returns to the original track.
djmartzian
47
9
By Skoda it works by A5 with SW 3302
Hello,
I can confirm that the above is NOT true. Automatic Lane Change can't be enabled from Assistants menu even after Side Assist has been fully retrofitted.
A5: 5WA980653C version.
Upgrade to >=3400 version is mandatory, from the info I've got so far!
cairus
1,575
552
Hello,
Which Car? Seat or Skoda?
