1.0 TSI brake upgrade
sebatje
11
Hi,
Is it possible to upgrade the front and rear brakes? Front caliper seems to be sliding on the front spindle...
nd-photo.nl
4,478
535
The Netherlands
youtube.com
If you want to upgrade, buy some A-grade discs and upgraded pads (look into EBC, Pagid for instance), check if steel braided lines are availble and make sure the fluid is fresh (max 2 years old).
If your brakes are in good shape, but you lack brake performance, then investigate in better tyres. You can have the best brake discs/pad setup, but with shitty tyres, you will not be able to stop faster.
Reactions: Mr Pig
DEAN0
Old Git
Feb 1, 2006
5,437
Preston - UK
What exactly is your problem?
I don't understand "sliding on the front spindle".
You can in theory bolt on brakes from the bigger engined cars.
I think they mean that the FSIII brakes on the smaller engine cars don't have a removeable caliper carrier.
The caliper carrier is the front hub and the only way to increase brake size it to replace the front hubs for ones with a bolt on carrier.
Reactions: Mr Pig
