MK R BOY
162
Hi All
I need some quick advice please, I was driving home when my ECP light came on the car lost a little power, running a bit rough and mainly hunting for idle.
The OBD reader is coming up with
1) 16396 BANK 1 Camshaft A, Advance setpoint not reached
2) 16706 Engine Speed Sensor G28
Im thinking the sensor has gone right? anyone know where this sensor is and if its an easy fix, any videos??
I managed to clear the fault and started the car, was it a blip or change the sensor???
Any help really appreciated.
So, the car broke down after about 15mins and wouldn’t start for ages. After a while it started and I got her home.
i decided to attempt the sensor, wasn’t where I thought it was and was a bit of a pig to get to without moving a lot of pipe work and the oil filter. I managed to replace it though without disturbing too many bits.
The ECP light has gone out and the car started first time. Fingers crossed all fixed.
So an update
The G28 sensor has been fixed, no ECP light.
However the engine management light has come on, when I run the OBD reader it is showing the 17544 System too Lean warning.
It is still on the original MAF sensor since 04 and the other culprits seem to be the PCV air split pipe thing, I've no experience with looking for air leaks at all.
Can someone provide some guidance on what I should do next please??
Check all the rubber pipes underneath the front of the engine, and on the right hand side.
They may be a split, or even if there isn't, anything that feels like plasticine will need changing. Creations Motorsports have all the silicone versions and there are diagrams on their website.
Hi alexis
thanks for that, I’m struggling to see a diagram of the engine and pipes tbh, can you post a pic?
can I check the pipe work from the bonnet or is the car going to be needed up on the ramp?
is there any point changing the MAF sensor, obviously that is an easy fix but I don’t need to waste money if there is almost no chance of it being the problem?
edit
so i have an OBD reader, is there a way to check the running of the MAF sensor? ive heard you can run the car with the MAF disconnected and look at the mixture settings. I’m not sure quick how to do that though and what settings they should be.
Disconnect the battery for a while and reconnect due to changing the sensor... i had todo that just changing one of the folding mirrors. also a old thread on same issue you had https://www.seatcupra.net/forums/threads/engine-speed-sensor-g28.331128/
Thanks Nam
I decided to buy a new MAF sensor anyway, they are getting hard to source and its over 20 years old.
Ill disconnect the battery change the MAF and reconnect. hopefully will reset both the G28 and MAF. I've got a smoke test booked as well in case.
Thanks Nam
Not wrong, euro parts use to stock the OEM I looked a while ago and it was hard to find one then.. every time I change oil ect I take that maf out of the housing and clean it with electrical contact cleaner and housing ..
yea hope that works
Thanks Nam
Try this https://www.hydra-int.com/petrol-power-blast.html i use there additives as im on Diesel and they work well after using other brands over the years and they are not a one shot solution as its concentrated
Hi alexis
edit
All the pipes can be accessed from the top of the engine. It's the pipes that connect to the rocker cover and the pipes under and around the inlet manifold.
HI All
So the smoke test should leakage from around the inlet, the garage is concerned that a lot of the pipes at the front need replacing too, however everything that is required is obsolete, does anyone know where I can source new pipes from?
get the part number if you can, and buy them from anywhere, ive got an amazon pcv pipe kit that i bought a while ago and its fine.
Awesome thanks, I need help with a part number if possible though.
Looking at the engine, to the right towards the air filter is a round plastic thing, its the crankcase oil breather trap.
There is a pipe that plugs into this trap, its quick thick and comes from the engine into the trap, but has a third inlet/outlet underneath, there is a pipe connected to this third opening.
Anyone know the part number of this?
is it this one you mean?
yes I think so,
Its not a great diagram but is the one SEAT gave me, they said the part I was looking for was "10", and part number 06A103221BK but it came today and its not even close.
So to confirm they said the pipe I am looking for is attached to part 13A NOT 13A
Looking at the car I think the part I'm looking for is 9A, don't suppose you have a number?
looking at your picture thats the right part number for 9a, it just looks a bit different because in the diagram it looks horizontal, but it connects to the y pipe and the t pipe underneath the inlet manifold. what engine do you have?
ok thanks
I've looked again and all of the ones available don't fit the 225bhp bam engine they are all 180, what on earth could be the difference? the brackets on the pipe also look cold welded on and none of the new ones come with brackets.
