Tell
Seems Microsoft is now offering the Windows 11 upgrade to unsupported machines. I note on Microsoft user forum people seem to have got it but not 24h2 which is a can of worms for some:
Microsoft speaks with forked tongue on their support to put it on unsupported hardware. So it was always going to be an interesting one as people moved from Windows 10 to Windows 11 and tried to get onto 24h2. I don't think the unsupported hardware enforces the memory integrity side of it so probably installs better whilst fully compliant hardware on Windows 10 could stumble on W11 24h2 upgrade. SSD and appropriate memory and processor is required. 13 year old systems happily run on it but obviously not for gaming. Doing the task they were designed for all those years ago they happily function on W11.
For those that do nothing they probably will get hit by a virus post October as the article mentions. Like when NHS PCs got put off line in the UK since security patches hadn't been applied with Windows 10. A corporate thing of enabling security patches as the system manager deems. No more security patches for Windows 10 users unless you take out a software warranty with Microsoft or upgrade to Windows 11 or junk the hardware.
Upgrading to W11 24h2 is hampered for some with non compliant drivers and memory integrity of drivers subsequently installed and non Microsoft virus programs. Probably best to leave the drivers alone first on all and if using the ISO you toggle to not update now else you can introduce rogue drivers non compliant with Windows 11 upgrade. Will stop early on in the process at 20% or so. If it gets to 70%. Probably memory integrity see the other post. That was my issue on a fully compliant laptop. Was an Adobe DVD driver that had been installed probably via Lightroom. Fault finding with vague error codes is the order of the day.
Reactions: jezyg
Another wonderful vendor, chuck out an OS that renders computers redundant because of not having a TPM 2.0 chip, I did the registry workaround on my funnily enough an MS Surface. In my environment we are buying Win 10 extended licenses as we fight with tech debt and systems that would fall over if Win 11 upgrade was applied. Linux is so much easier to deal with overall especially on the security side. Microsoft is in the realms of 'too much security' that has become user unfriendly and almost a battle to implement without issue.
Misconfiguration and lack of patching are the two main reason breaches happen - the game of 'whack a mole' with vulnerabilities. Sadly until organisation's until they see security for what it is 'protection' rather than a financial drain, something they don't want or tick box. Incidents will continue, with quantum or Q-Day 3 to years out, to bring potentially a whole host of pain. However, organisations and vendors are still trying having a bromance with AI as they blow their privacy up from lack of policy, procedure and understanding.
Interesting, especially as the Forbes article linked by @Tell is six months old. :-k. :-k
Must investigate further.
Guy
Sent from my Galaxy S25 Ultra using Tapatalk
This website is reliable.
You would use the 25h2 iso file rather than 24h2 as per the text. The method I have used for the last two years comes in at this point:
2. Is the 25h2 ISO etc.
Find that bit of text in the link and down. The server method as its called was put in by Microsoft so IT departments could install Windows 11 on non compliant hardware. It's the method I've used to install Windows 11 24h2 and 25h2 for the last two years although there was a quicker method to go from Windows 11 24h2 > 25h2 this year by patching into the migration files.
Always have a full back up just incase. That bit where it says update drivers now, you toggle to off since its faster. Then once installed you allow it to do the updates.
I do run it on old PCs which had Windows 7 on them originally. Migrated to 10 then took the plunge to 11 when it came out. SSD memory is useful to stop the drive thrashing about so both of those 2011 /12 tower units I put 1tb SSDs in them. 16gb of memory. If you are not gaming on the hardware it's perfectly good to use eg. as an office PC. I dont game so I have no need for that 😉.
Reactions: Bahnstormer_vRS
