How to update the firmware? (Current version 1803)
Dec 17, 2024
I own a 2020 SEAT Leon 4 1.4 e-Hybrid FR, and I'm looking for guidance on how to update my firmware.
Current system details (pictures attached):
  • Software version: 1803
  • Hardware: H56
  • Hardware ABT: H37
  • Software ABT: 3074
  • Navigation database: 20.11
  • Radio database: 1.30.24
  • Codec version: 3.1.4
I've seen that newer versions are available, but I haven't found clear instructions on how to perform the update.
  • Is this something that can be done via OTA updates, or does it require a USB update from SEAT?
  • Is it possible to manually update it with files downloaded from somewhere?
  • What improvements/fixes come with the latest updates?
Any help would be greatly appreciated!
Thanks in advance!
Nov 18, 2021
80
21
If I am not wrong, you can update to 1896 with a usb pen.
Can't remember if in this forum someone posted the files.
Good luck
Enviado desde mi 2312DRA50G mediante Tapatalk
cairus
1,572
552
you could also update directly to 1969. There is a risk with every firmware update
Reactions: jeeeefff
Dec 17, 2024
Hey everyone,
I reached out to a SEAT Authorized Service Centre to ask about updating my infotainment system firmware. Their response was:
"As I mentioned over the phone, the software update will be requested by the car itself, and you will then have to accept it to proceed."
This raises some questions:
  • For those who have updated manually, was the car supposed to request the update first?
  • Is there any way to force the car to check for updates?
I appreciate any insights from those who have successfully updated their system!
Thanks!
Dec 17, 2024
I never forced a Update
Thanks for your response!
I've seen in other threads that you (or other members) might have the firmware files to update to version 1969. Would you be able to share them or point me in the right direction to download them?
Also, if you have any instructions on how to safely install the update via USB C, that would be really helpful.
Thanks in advance!
Reactions: ivangladesh
Mar 16, 2025
Italy
Thanks in advance!
I have a 2022 Leon which I've recently bought. After having fixed a problem related to the connectivity (the globe icon was gray), I was able to add my account and after that I immediately got an update notice from the infotainment. I think I was on version 1803 and it upgraded to version A896 which I believe is 1896 where A maybe stands for Air (not sure though).
I am wondering which is the latest version that the car can get OTA.. The update happened yesterday and today I've used the car but no more notices were shown, it's a pity that there is no "Check for updates" button, I really can't believe there is no way to induce a check.
Maybe tomorrow I'll try to perform a factory reset and a hard reset to see if I have any luck
jeeeefff
67
8
just making a note on this thread to keep tabs on it as I'm in the same boat, currently on A896 and did get a notice this morning about an update before driving to work. But yes I have been advised to not force updates as this might conflict with other devices though some have said they've been fine too but will stick with over the air updates for now.
I have the Seat Leon 2021 (mk4?) and have issues with SOS yellow light flashing during a drive to a new place and my SAT nav no updating on the map, actually showing that I was off the motor way when on the motor way with random pulsing forward and back, in and out on the map. stopping somewhere safe, turning off and on didn't fix the issue, but turning off Bluetooth and using phone directly for navigation did as I was in a rush. Will try again full link on known routes to avoid the stress and to test further if the issue happens repeatedly.
I'm hoping its an issue with a dated navigation database as I'm not sure if the car pulls the GPS data from itself or the phone during android auto full link.
Have you had the same issue on your car? Attached images of the firmware to when it was brought and after first update which happened after factory resetting the car and setting myself as the primary user.
jeeeefff
67
8
did perform a factory reset mate? If so did that encourage any more updates? I'm also in the same boat being stuck on A896 and semi pondering updating to 1969 once I'm 100% confident I wont run into issues. Luckily I don't have the firmware but keen to get one that works for my UK car.
I do know my SW train is MOI3_EU_SE_R9690L
been trying to locate the file here but not sure if this is the right one. again just making notes and prepping trying to make sure its all good before attempting.
Apr 15, 2025
Did you find the right one as mines on software 1790 so desperate for an update
jeeeefff
67
8
From reading the forum, many folk recommend you get over-the-air updates first, getting your car to at least A896 which I believe is 1896 prior to updating to 1969 to avoid potential issues/bricking.
I believe this is only possible when you are set as the primary user and connected to a wifi connection but it was very random when it felt like doing an over the air update.
Problem I'm having is I cannot even make myself the primary user as on infotainment screen when select make primary user it comes up unable to open app 😮💨 had the car 3 weeks and has me proper frustrated
jeeeefff
67
8
Yeh I was in the same boat as I've only had it nearly a week more than you. It's definitely a lot of faff mate and nearly returned it.
I think I had this problem, trying to recall if I resent the car to factory defaults fixed the issue using the infotainment system, cant fully recall where, possibly in systems settings as I could only be a guest.
Still have a few on going issue as the update, well being snappier, didn't fixed the other issues I've had, in my signature.
Yern
697
352
My previous MK4 had 1804 from new which updated to A896 OTA so doesn't require Wi-Fi, if its still available OTA? It was a big update (several gig) so did it in 2 sessions I think. I take it you have 2 working keys when trying to become primary user? My new car failed Primary User registration at delivery so I drove off to try at home later which also kept failing without realising one of the keys (which lit up) didn't lock/unlock the car. Once the dealer received a new key and coded to the car I tried Primary User registration which was successful.
jeeeefff
67
8
Yeh it took me a while to get from I believe 17xx to A896 OTA. I think it was two parts, just took a long while for the second part of the update to trigger, funnily enough only when I was about to drive home from work and never when its on my drive.
Thats right I have 2 keys. I couldn't become a primary user when trying to link it to the Connect phone app but resetting the car (or profiles?) allowed me to be the primary user and allow OTA updates. Its been a very odd experience so far, trouble shooting more than driving mainly as I want to make sure its safe
Yern
697
352
I had already added the new VIN to My Seat app before delivery which uploaded navigation history and radio stations on registration but kept getting the primary user nag warning and no navigation traffic alerts. Then after new key coded did the infotainment Primary User registration first, then went into the app which updated itself.
Reactions: jeeeefff
jeeeefff
67
8
happy it worked out, it took me a few attempts, days even ahahah. I do recall needing to put the VIN into the app also.
Reactions: Yern
krmzl
thiccCoopra
Apr 18, 2025
17
Netherlands
Contact Cupra, I had to do a few steps, they were quite responsive via e-mail.
I acquired a Formentor last weekend, currently on 1899. Not sure if this is the last version?
