Model Year 20/21 Formentor ACC help
tommyfulf
55
I'll have a look but what section is it under? Is there an option called mode? I cant see an option there?
tommyfulf
55
Apologies ive now got to the car and changed the mode to EOL.
In gateway module under adaptation I cannot find anything stating KLR
Is it under a different name?
tommyfulf
55
So I've solved the module 13 issue.
The unit hadn't taken the login security access code 20103. Re entering that i am now able to save the changes to installed capacitive steering wheel and installed travel assist.
I still need your help with where the KLR option is within the Gateway module, I cannot find it anywhere
cairus
1,610
564
I'm not the type to chew everything up front... Gateway, adjustments, target installation of sub-participants, KLR on active
tommyfulf
55
Again apologies but under
Gateway>adaptations>
there is no target installation of sub participants 🤷🏻‍♂️
I also can't see a KLR option within any of those categories either
tommyfulf
55
This is the closest to what you have said but still no KLR option in there
cairus
1,610
564
You need a Firmware Update and Dataset i think, i will check something
cairus
1,610
564
Isn't KLR this one under that section? --> "Control module for steering wheel touch recognition"
Sent from my 24122RKC7G using Tapatalk
I have coded every TA retrofit under gateway adaptation, sub subscriber the klr
serdar_18fr
563
Yes of course, I meant the item under the section you were already talking about: "Specified installation of sub-bus users"
serdar_18fr
563
@tommyfulf said he could not see a KLR option and I'm saying "Control module for steering wheel touch recognition" under "Specified installation of sub-bus users" *is* the KLR option.
