I'll have a look but what section is it under? Is there an option called mode? I cant see an option there?
Apologies ive now got to the car and changed the mode to EOL.
In gateway module under adaptation I cannot find anything stating KLR
Is it under a different name?
So I've solved the module 13 issue.
The unit hadn't taken the login security access code 20103. Re entering that i am now able to save the changes to installed capacitive steering wheel and installed travel assist.
I still need your help with where the KLR option is within the Gateway module, I cannot find it anywhere
I'm not the type to chew everything up front... Gateway, adjustments, target installation of sub-participants, KLR on active
Again apologies but under
Gateway>adaptations>
there is no target installation of sub participants ??‍♂️
I also can't see a KLR option within any of those categories either
This is the closest to what you have said but still no KLR option in there
You need a Firmware Update and Dataset i think, i will check something
Isn't KLR this one under that section? --> "Control module for steering wheel touch recognition"
Sent from my 24122RKC7G using Tapatalk
I have coded every TA retrofit under gateway adaptation, sub subscriber the klr
Yes of course, I meant the item under the section you were already talking about: "Specified installation of sub-bus users"
@tommyfulf said he could not see a KLR option and I'm saying "Control module for steering wheel touch recognition" under "Specified installation of sub-bus users" *is* the KLR option.
