Don’t know whether you’ve found the same with yours also being at estate, but when I’m “making progress” the chassis flex at the rear is ridiculous - I can look in my rear view mirror and literally see the back end twist out of square!
I considered a K brace, but as I regularly put the back seats down I don’t want the hassle of having to remove it every time I need to use the full load space. So I’ve just picked up one of these bad boys:
When I bough the car, it was no secret that the brakes needed to be done. My last cars have had Brembo discs but for the Cupra I wanted to try another brand. Friends told me to go for Zimmermann, so I did :yes:
Was able to source 4 discs + brake pads for 413 euro including shipment. That is a steal! Unfortunately, the rear brake pads did not fit, so I had to source another brake pad set.
AP1GczM224vWVkVY0T5CVRyXMRHNmkoWd_pyd2jvhEd1jNVpiavXVFAvnny3SeZJINP7ADsRdva3VFtSA-SSbBqm5vn7lUGRcTlh_ukAmpJOnA4D6Fo2lfDbnrNzbow_Qku3e-Ov47sFUZZ_MWGepJf4jLziKQ=w1920-h1080-s-no-gm
This is how the front discs were looking
AP1GczMfUlHWSd6o24H8WtYjLNbrxkW6ZYFcQAqTYYPjKmy0yKttSaibxKOdxwFVJ4oJrvANvbbfkWsChRn19_mxMQfTLQWHtlemDSRWuhxlj0wgzk0U1W8IpSlaNX-rMtTqLsD1zQS969Y-L_x1d2ajrl7REQ=w1920-h1080-s-no-gm
The amount of rust in the disc was alarming
AP1GczObYXeNPMe5729YwFHW-pRPOm4GdesGcVk7hzdu70WfuR3g6JA5X0xhvTHqyw7yd91SKdK4MyvLcd35N7wrS73tRcDiUMCM6X_dMdwp0DNuaP5cjyGygND3XEb5QJpJ3QmiHBD5U5lGjWgBGKDdxolu1A=w1920-h1080-s-no-gm
The caliper looks good
AP1GczPa564XgBSamOscASreRIHTgVNo-ZDca_hhjEmXBj-sMexFIYD8-3YCSTAAYNyvKc4nQv4845oX5NCfrodXMPnCcdKV6n2I8orVB9_CUzgUO65E4HB243NEWW3rqnnZK-kQckhj8VksR1CA7IxAB9zv8w=w1920-h1080-s-no-gm
The rust was also visible on the inside
AP1GczPGykgLM7MGXOlMH9VhJxYgsOvxN_KEncjwl1hM6uMcaY_jWsDQGAfioWBTWA6a3sVgg3UmAfzrW8G19aECVHUxTdVNrtZbD-YvM-ieJigSqdYvfc8pvCusM5xcL3u8JttresFVb_VQRBIBg05GzliwEQ=w1920-h1080-s-no-gm
Both rear calipers look like this. So they both need a little cleaning and paint
AP1GczOSyMXaBTH-irQLXhnOwwqtRSOWZuJXpHF38UCdS0trHb3tazqVf7GJP0Z70AjOZ_h8A0d4TXTT22DViXm6FrrTf5Kk4K6UTM2klD9NFr9WHGtqHHL-NrWILS3HsW5y8POzCMvOv7Z6quVFJfd-7mtbew=w1920-h1080-s-no-gm
The rear was rusty af, so new backing plates will be mounted.
AP1GczN4eE0p18mjzVWgaWTfE431fIsyQMzl4ImE-PhZ21NnVHLP5Q0F2_qeC-DXqN0pR3XCW4lTGYbd4xgtfu6U1wrk3f7sKsmVLZMa6yiemicegOoGmnxZ45tP0oaHS7r7AJWySBUedsOO2qmaOJdWCNh_qw=w1920-h1080-s-no-gm
Same goes for the arms, they are rusty and will be replaced.
AP1GczNj-OMxCppC0-LFSBSMYHXHIqmgcAvaLPHf_EAsyWS2ysBJB2k2auvlUkJwdQ2LvS2jPDb4BHd1mem0Si5qgkyeULwwPbyOSdC8iTxMGnEPcFFwBhiH5cOkk3_bi37Lou1ykaXj1gIR5s47gL8b4xga-w=w1920-h1080-s-no-gm
Not gonna lie I’m not a fan of the burnt tips - they’re a bit too JDM/Subaru for my liking. Personally I’d have kept your previous ones, or looked at a set of Akrapovic style carbon ones
But if you’re happy then who the heck cares? ??
@TripleBob I also tried out the "pikey r600" mod, but reverted that as I wanted to retain that airflow on that side of the engine. I dont know why, but I feel better knowing that air is also cooling some stuff in that part of the engine bay.
I believe in my air diverters, so I havent removed them and checking the butt dyno if they made a significant change :LOL:
Even though I like my current intake, I will probably end up buying this oversized RamAir intake:
Reactions: TripleBob
Finally some performance mods, a 3.5" > 3" downpipe. The kit was delivered with a 200 cells sportscat and also a decat/testpipe, so you can choose whatever you want.
Decat is too much, so I decided to use the sports cat. The downpipe already had heatshielding added, which is a big plus for me!
Package a little bit damaged
AP1GczOBEebMjKL2OwO5IpNvNYcS9pUCd6Rhprt0ekPbZDJwVxbOQ5Q3ARl_l4x9D7AZAywWVqV0URN9SSOWS3LbeEjEn1pUvddgsz8ZKXB2Ao6lsJgnLQ90iBP1f7blaBSirJOvJf3clKGDZg0GhPmD9VMdMg=w1920-h1080-s-no
I forgot that the kit had both decat/sportscat, so this is not how it looks underneath the car haha :ROFLMAO:
AP1GczOmafcjQksKAUTSeK0OsfNkfwddnuoIS0h4D63r8h8QvZ7mGd_LKu9dVkLrJ_VtoxXFQ5m7HjaVSp4nhDac4liwNB5XTK5yawfbLcrz852o92J3bzAJ4e7UN9zKmrxZO2Gpq91Z_ArM4LiV_sP307mIQQ=w1920-h1080-s-no
The heatshielding in all its glory!
AP1GczP2t93U_Hzw6DKHK0-vApu7Q00dpyFdsn4_hW44RHoviT8gJym3YEaJvbZoaZpxFwf2QMwhVnheMTFpRzWju9ZYinHh82Nf8p06K00UYQCr_g57fbXxPAe4f4WWp0632iQxvVstmQIbVtE_Wv5Dg3p9JA=w1920-h1080-s-no
AP1GczP9SuA-N_o_3JEXsk8WHxod7ySyS65YQ8Jpevd2C_6tGsqfUEDLC-bsr3p7qS0KIr_WcjVzI1Xn6DgQAZ1CHZ6slqQWvngQE02K5z8WcPJJvHjb03AiKYKt7P9cSK0Xtor73HQzuKfcFnv8P1NeEZsJPQ=w1920-h1080-s-no
The flexpart is reinforced and looks good
AP1GczPCI5KXROGx4jrSbqPanEhdkls7aE8AVp8SToOaAGUyxHVyPwwqt6gg86bj-WFzHwuJlVli9MESieeKEzyd3u5x_3G1UUcaZjJh9lAv00IV_DXwfdbjqOdooigsQRuYYQJZT2gYTOrV98NMhTmOYFDDQw=w1920-h1080-s-no
Nice welds, also on the inside!
AP1GczP7rMXrr9KFjxUAR4cWhBKMup0_uJNBMfngI7cbiXNwbcliOvo6NQqKE4TEkPNQV3kxcKeFOBV6Mv1QXlfXlXrcUFUMJ-QJSVEUfqkQvtVwDG7yFLnWquBt7KaXQjdPpe6kFPES88BdYjGgZb9kgOjD9Q=w1920-h1080-s-no
AP1GczNhHS9ncma9IyQaz3SqVvaCbwreAwgNjUZ2r1PYrsK34-EPaDKhaKCdOOc183XbZlVtuD_fc6m0fVg6KqgKJPbGEq6AaGvc3z82ffPTRq9DtBnDb7Oh6XVU3RUYMJzPa1cm-yBj9DRnX7lT71odJlKYvg=w1920-h1080-s-no
Sportscat also looks good
AP1GczMxFGI3o2d6QIi4VqsGKwkJzYgcJBGMfhGYzWczv_O1RckJnpL_qycySkVSSjrDaBaMn2eO9j3uXLbyDFsngymbCqYU-0KT0_f7g5MbJh1cNtVYmvvgVqbcolAAFoujGwHt3AOecde86sdG17-jCHxiRw=w1920-h1080-s-no
AP1GczO0drWTCEGRTnCq3bE1l9Z4W9OmXC6akzgIDPAPWlscD-6IhuVuUMr__H_DfvjKzxmSCHAc6ow_S_i0KNNZOluSZIfxDnyclYC5YOM6bKSH8GNwI4NQ6tuJIagup0Vzp2kYqtxLvQENhM1JbVNov0omlw=w1920-h1080-s-no
AP1GczNc2J8ePJE5hEzEtbwjEaJxZkd-w0ggOhzjiwU7yRGrkMT2Ov-lC1JmcqxSWDMZ5pwLNBBlK6Yvj-3CdL51cqYYg5btMZztQMYSdyLprNjK9eRPl3uuwUNjfviN69r3P2cQuGSU3VQc0uv3efhWwg9Yag=w1920-h1080-s-no
Reactions: tracktoy and Mo_86
Really nice Andy!!
Which one is this? (I was looking at a 4" Trackslag DP, but the extra import taxes are killing it...)
Also bought the beauty cover. Needed to make an adjustment for the boost tap, which makes the MAP sensor sit higher. A little bit of dremeling was the solution. I think it looks way better in person compared to pictures
AP1GczMkI-WFLZECYuwB4hCa7QNxeWv4BBImCTi6n1JoStCPb8mdsF7wzV1M6OnRg4HsujV9vskDsio3tMAXrf7cNv0UBUWZNRd2pcqTSKKIBMmBE_WHFUNoPzSpBdp47kc41E9qdF8hLh_Iiy4HYApgVWwfeA=w1920-h1080-s-no
AP1GczMmS8wQJP7BUMVEt4Z0rvocT7HHENc2knZz3xoIk22Hs8A4xnYmTfOzrI7FCXqiw0BkvTS6ztB8ni7785WHc-cEvXFLNHl6wFAiXLnr0RtbIw1hkxNRjefI_KTyMAIufCO1D28OBofrIGuOAoLS_EzQVA=w1920-h1080-s-no
AP1GczMbRvtD-PsUxP6YGjDcs_gs4_G_Tg1sUvt0V7YGDHX9TVSZ37_5A-UgCNjxOw0-Mz78VBINipz7qn4ZIl0MMAyhma8SHKHKTsyBn244fiRghl8ghT70Mpt0Y8MPt84ixZSytYFrjqbid3lZ_4hDcFRTyw=w1920-h1080-s-no
This is where I needed to make a little space for the MAP sensor
AP1GczMzrPtysCtQ6fw5l4f1paSLp60jX9VUvSdGXzV7jDSERWhoLFPcWysTxx2ncdUzQfFBh7bjS3xx1FlxHH4AYzSW9mhW-IKqYtWwmUGOqkAbKH80M68Ma3DxulYiCIXUaYgtYWzzu2CDYnO0tD5mR2lHSg=w1920-h1080-s-no
AP1GczPuIiFqvhfiTis8qOUcDQ2mlshBFUD8r-V3lsNmTb-p8g0h1cyQTiHSq_3S-Yk0eJn_fHZ5NoaQ6H5ZLsWZ8KpQsx32Txnez5YxKCxro75TVWk9JQfbNwKj8vZdSqsWuetLASCCcB_EvJgaf4e45Zk0mA=w1920-h1080-s-no
AP1GczNKlleYEJF5PFhZota35TGe5dOgNVxcDxpc7VrHdF-23X5aUbXR3EdvOgNrtuk--TRRHp-xz-oTXBq0pQUqm-7AJEuNfD8oEWd4L_tRecOXRG9HxCEd5_c3GJ3iQkQ6xWp4NqH4A2l4oQkB0Ko9lFqo3A=w1920-h1080-s-no
Before
AP1GczPTY9uKndPSu7cV_DrqKHPocEk3oDaZPt8hK0Iv0WuOWcM0pe_ZVUih1CBjOPetB6xtekFvRE1j9zArE1BFO6MU1OHSdIRf5KHzUKLl8uiW0ZBwzCUaRIApczYbpUcQtrkarAGHW_5lYp8ZTgr9oRLiew=w1920-h1080-s-no
AP1GczODp-W_hEIH5PsxrZANxzMjreuWU6ywkMHvf143oEGipO95H-dJbUVfwk1RpDrT3vOdg1eC82ZbFn5La7SVnLJuaP4AbYwWBb0yRi_9HgGHTXzIf40dUrEUkl35q-XwvkXKbz5CMcK8CTeWD_gKwm5D9A=w1920-h1080-s-no
And after! Happy days :cheeky:
AP1GczMkveMRpEgooosSXcbCb9bHPaMm5ztJumMJN1TP7TT9k0cydC03VAGMA6Mg1qkQWWCj-9Jd4oODm-HjCoE-QBDplaATNXgYDjQBRJ4z_icAv2DseVY4653m3SobsanRS9IajvV22luQMfpPRA9m59sPLw=w1920-h1080-s-no
AP1GczOyASKgTzTvL12O3-OXdgidfAfqcIDzgnyWM8u518S6b21Gs09ZEa2OaXtFqcbowOXqlyoTBhdOV4CCwxNz5GTPMg_G7AJibgMjS-KMdphLhPrHINEFwzMiTbYMzwAwq8sI_RKMskoa3jD-5egyiKDtSg=w1920-h1080-s-no
