Madkaz
17
Belgium
Hi guys,
I got my new Cupra Leon Facelift, I bought Viofo a329 dashcam an I'm in the process of hardwiring it
In the manual I see the fuse box is located on the right bottom of the steering wheel, the thing is I took the optional knee airbag, and on this panel I see the "airbag" write on it, I'm definitely not confident opening this panel since Airbag is stated on it.
Someone has experience with that ? Is the location mentioned in the 2025 manual correct ?
Thanks !
(Image found on google, the manual has a similar image)
The label "Airbag" is required by law. Anything the user can remove without a tool must be labeled. Access to or touching the airbag will likely be possible behind it.
That's indeed what I want to avoid, accessing the fuse box without touching the airbag
