Full Link activation after software update
cairus
1,572
552
In this case, I would recommend updating to 0480 and then applying the firmware patch. Or try the ToolBox system swap patch again.
Tell
You mean it can't read the SD card or its installed on the bench. No SD card no music playing from SD.. :unsure: isn't that an omission. Is that why the navigation isn't working if its not seeing the SD card.
I'll take that as on the bench installation and may be not seeing the SD card either....
Sticking with the official 512 firmware here on the Arona.
cairus
1,572
552
You can't install ToolBox Classic via the SD slot on your device. You have to open the device to do this.
Jul 4, 2025
29
What works the navigation. ? In 480.
I recall someone on here saying the mib2 standard toolbox doesn't work on the 5 train unless it's fixed now.
I am not on train 5. I am still on train 4. I only updated from P0479T to P0480T. After patching the cpu, thanks to @cairus, I got the navi back working again. Toolbox is still installed, but I don't want to do anything with it anymore. The only thing I would be interested in from toolbox is to use CarPlay navigation at the same time as the onboard Navigation, but I don't want to temper with it anymore. I am glad I got everything working again like it should.
Reactions: Tell
