LeylandVCDS
657
422
As per title, is there anyone in the Preston or surrounding area with ODIS? Willing to travel a reasonable distance, not expecting anyone to travel to me. Needing to calibrate my reverse camera on my Leon ST - got the calibration board, but need ODIS to complete. Many thanks.
I tried with ODIS and the VWG calibration board when I had mine and it never went through.
  • Sad
Reactions: LeylandVCDS
Thanks, not the response I wanted to hear.......VCDS, VCP and OBD11 all failed, so wanted to try ODIS to try to get rid of the not calibrated fault code
You can't calibrate them using real values as there aren't any suitable datasets available for the mk3 leon. The camera is mounted too low
Ignore it, calibrate with made up values (pointless aside from removing the error message, as the guidelines will still be way off), or fit a lowline camera
I've tried calibrating it with various made up values, but always get the same error - calibration panels 1 and 2 not recognised. I know the lines would still be off, but don't actually use the lines as such, I just want to clear the constant error
