New Tyres have arrived, next step to get them fitted to wheels and then I have a great couple track days booked in September to see how well they work out on the track.
Do you have the part number?Made a short video how to replace your washer jets, and possibly upgrade them to the "fan type"
Click:
ND-Photo.nl 's - Seat Leon ST Cupra 280
Swapped to the dynamic indicators, which are a major improvement over stock. Very happy with this cheap & easy modification! Looks way more modern (y)www.seatcupra.net
Replaced my AMG flag with a Cupra flag. This should please a lot of people here haha
Even though its not the 100% correct flag, I could not find a good Seat Cupra flag in white. I need a white flag, as this helps lighten up the dark garage.
Double garages with two doors only take one car since you can't get the big one in. I watch the neighbour with their jag. The wife's little one goes in one side but his stays out. He'd have no luck with a single double door. I can't get the Ateca and Arona in together. Decided not worth the hassle.
White lined the garage which makes parking easier. You make a mask with wood and spray paint it. With a rear white line you just put the car into reverse and see the white line... that is what the partner does. Standard operating procedure on parking with a car which doesn't have 360. Slap it into reverse. Saves putting blocks at the front. Dangle wights from the roof etc that touch the windscreen.
White lining the garage. Tip of the day ?.
