Adding small bits that's missing due to VAG's terrible cost cutting
serdar_18fr
594
Hi everyone,
Whenever it's possible technically & financially, I try to do retrofits where I add missing features.
My new Cupra Ateca is pretty loaded and missing only the things that have become victims of VAG's cost cutting in model's later lifecycle.
The car is only three months old but I already added dual tone horn, which I believe makes a nice difference.
Here are the before & after videos of this retrofit, which required only a new bracket, 2 new horns, a connector, a self-made wiring loom and also OEM bolts & nuts, if you're obsessive-compulsive about the originality of parts like me :)
Next two retrofits which I plan to realize in a couple of weeks:
1. Washer fluid level warning (A new water reservoir, a water level switch & its seal ring, a connector and again a self-made wiring. Also one item of coding in BCM)
2. Heated spray nozzles (Two new nozzles, two connectors, and a self-made wiring. Also one item of coding in BCM too)
These were available in my previous car, a 2018 Leon FR as part of the winter package.
But in a car seven years newer, a supposedly semi-premium one, they were omitted by the bean counters at mighty VAG.
I hate these stupid decisions and try to fight it whenever it's possible.
Tell
What put me off the Tarraco stuff that I could specify on my Ateca you couldn't with the Tarraco two years later so decided I'd stick. Was going to shuffle it around in ownership so stuck. They lost a sale. Lot deleted off as option you could specify. Adding bits and bobs is something different. This is when they moved to selling the cars like VW with a number of build options to just three segments or so of models in a marketing strategy. Where I dis Seat FR models when I see them since I know they are compromised on the spec but the owners don't :oops:. Cupra get those VZs.
Probably a T Roc that nearly ran me over in an Aldi car park without reversing cameras I bet. Plunged straight backwards. Cars without reversing cameras and 360 ultrasound shouldn't be sold these days. Basic safety feature.
Reactions: serdar_18fr
serdar_18fr
594
I always wait in fear when I parallel-parked that some car without front and/or rear parking sensors would bump into the front of my car and it would break my radar's calibration and I would have to deal with fixing it!
  • Sad
Reactions: Tell
serdar_18fr
594
Hi, everyone.
As per my original post in this thread, I was planning to add more small bits that were missing.
One of those was the washer fluid level sensor and the other was the heated washer nozzles.
Below is the list of parts that I used and also the items needed coding.
Also I took some photographs, not too detailed to document the whole work from start to finish, but they might just give an idea about these retrofits. I can happily provide support if anybody interested in doing the same has questions.
The new wash water reservoir has a sensor hole on it and also two pump holes, instead of one on the original. It is designed to be used with headlamp washer system and the second pump hole is used for it. We had to cover & seal that pump hole using some ingenious ways. Also the reservoir is bigger than the original so it will be nice to have more washer fluid.
Obviously I had the opportunity to test the washer fluid level sensor and it worked without any problem.
But I couldn't think of a way to test the heated nozzles because I don't know their operating condition.
Probably BCM software constantly monitors the outside temperature, sends a current to the nozzles when it drops below the specified temp, resistors inside the nozzles gets hot with the current and prevents ice formation on the tips or breaks it, if any formed before.
Anyway, it seems there's no practical way to test that, please do tell me if you could think of any.
Best regards,
Serdar
5Q0955453BE Wash water reservoir
7M0919382 Seal ring
7M0919376 Water level switch
1J0973202 Flat contact housing
5G09559869B9 Heated spray nozzle x2
8E0973202 Flat contact housing x2
Also 9 meters of cable and some contacts were used for wirings.
Coding required:
09-Central Electrics
---> Adaptations
------> HW_Verbau
---------> Insufficient washer fluid -> installed
------> Window heater
---------> Waschduesenheizung -> installed
Bahnstormer_vRS
94
50
That's some good looking work there Serdar, although I'm not sure that replacing the washer reservoir comes under the heading of 'small bits'.
I lament several bits that are missing on my Ateca which I got used to on my previous Skodas; Octavia vRS and Yeti.
1. The low washer fluid is one; just means I check and top up more often.
2. The wiper parking going down one time, then down and a tiny flick up the next. To even out how the blade sits and reduce wear, and
3. Skoda's Simply Clever parking ticket holder. This I've been able to fix by getting the clear plastic clip / holder from my local Skoda dealer. You then prise off the plastic trim on the inside of the windscreen pillar. Screw the clip into the appropriate hole, which is already there as the Ateca is a sister model to the Karoq. Refit the trim job done.
A few pics;-
Guy
Sent from my Galaxy S23 Ultra using Tapatalk
serdar_18fr
594
Guy
Thank you!
Yes, the work itself is not so small, involving bumper removal and pulling wires inside etc but the importance people would give to this feature omission is very small, hence the "small bit". But not me, of course
Along with the previous additions & modifications (alloy wheels for winter tire set, exhaust replacement and dual-tone horn retrofit), these two almost completed my plans.
Parking ticket holder looks nice & useful, I might consider it too
Cheers,
Serdar
Sent from my 24122RKC7G using Tapatalk
Tell
Fortunate on 1. I got that. It came on once. Think it's on the winter pack in 2016 probably vanished or wasn't a subsequent option made available again. I know I was asked about it once on the site since it was ambiguous what was in the packs.
It's the option reduction that's been the issue on Seat. High spec got moved to Cupra on the Ateca side and the options vanished. Subsequently they got their own model range.
3. Use a bull dog clip in one car and a plastic glasses case in the other car. Skoda is renowed for its nice touches like the built in umbrella. As some of us know parking tickets get blown into a gap at the front of the windscreen. A4 folded sheet can be used to hook them out in an emergency. Lesson learnt.
Not sure about 2. but we don't have the road speeds for the wiper rest at fast speeds. I seen that on ours driving on autobahns.
I got the Skoda ice scraper colour green. There was a Seat red one... not sure whether you can still get that now. Goes in the clip in the petrol cover. One of those Skoda touches.
I like the way the heat pump is left off some of the EVs. You wouldn't want that in the UK.
Seriously?
1,480
1,075
A few pics;-
Guy
What year is your Ateca? Our 2018 Leon does the 'wiper flick' thing.
I also fit ticket holders to all my cars, since having a MK1 Octavia which had it as standard. It's a simple mod that you only notice is missing from a car when your car park ticket disappears between the screen and the dash or blows away when you open the door.:rolleyes:
Reactions: Tell
serdar_18fr
594
Problem is that they cut some features from Cupra's too. Even if you order the most expensive Ateca with the 300-hp engine today, you can't get washer fluid level sensor, heated nozzles and dual-tone horn.
  • Wow
Reactions: Tell
Bahnstormer_vRS
94
50
^^^^ My current CUPRA Ateca is a '23. My previous one, 70 reg MY 21, didn't have the wiper flick either.
I've got the Skoda ice scraper, fitted in the fuel filler cap as well, but only as I bought my Ateca from my local Skoda dealer who supplied it as a freebie for me.
Guy
Reactions: Tell
Loadmaster748
Los Dos Amigos
409
192
Surrey, UK
Hi everyone,
Haha...... the first clip is exactly what I'm hearing in my VZ3, pathetic! The second clip is the same as our Ateca and how it should be.
Have you published a guide somewhere on the forum to doing the retrofit?
Thanks.
serdar_18fr
594
Thanks.
Pathetic is exactly the right word for it! :LOL:
I haven't prepared a guide for this but it is fairly straightforward.
You need to remove the front bumper, remove the existing bracket & horn, install the new bracket & the new horns, then plug the wiring harness extension that was prepared before, try & hear the sound of them, and finally mount the bumper back.
It is fairly easy, but for professionals with the tools of course.
I used the services of a VAG retrofitter garage.
If needed, I can share the part numbers too.
Cheers,
Serdar
Reactions: Loadmaster748
Loadmaster748
Los Dos Amigos
409
192
Surrey, UK
Part numbers would be useful please. I had assumed that access would have been gained by the removal of the left or right side wheel arch liner, not the front bumper! What a pain.
I asked my my local VAG indie for a price to do the job yesterday, I should hear back today.
Tell
Guy
There were Seat red ice scrapers at one stage made up for that slot as opposed to the Skoda green ones. Might have gone out of production. I bought my green from a Skoda dealer and touch up paint given the paint colours are on share. Just different names. Same code.
Reactions: Bahnstormer_vRS
serdar_18fr
594
I have the part numbers that I have used for my '25 Cupra Ateca on hand, and they would no doubt fit to your Leon too, but there's a possibility that some similar but slightly different parts are used in Leon when it is specced with 8Y1 (Dual-tone horn). So let's not take that risk and find the exact numbers for your car using its VIN.
Loadmaster748
Los Dos Amigos
409
192
Surrey, UK
I've spoken to one of my two local VAG indies about this job, you are of course correct that the front bumper needs to be removed for this retrofit. For the sake of a couple of hours labour I think I'll let them do it rather than me mess something up!
serdar_18fr
594
OK, when you feel like doing this, send your VIN to me and I'll look it up.
Reactions: Tell
