If it wont hurt car ho cares! Eaven on startstop got it. Its down on turbo side sized. Going to other mehanic for inspection. Everyone is like dont buy tsi it unreliable bla bla bla. Im preaty shure they are better tha any tdi.As long as your oil light goes out when the engine starts that is normal. No engine will have any oil pressure when the engine isn't running.
Regarding your fault code - this will probably be a seized turbo actuator pivot. Quite common on the 1.4
A 1.4 Golf in my family had this fault - we managed to disconnect the pivot pin (it was very seized), clean/file & grease and a new circlip and all working fine since.
If severe you'll need a new turbo actuator
This thread has some useful photos:
How to fix the turbo wastegate rattle on the Mk7 Golf 1.4lt TSI (140/150PS)
Disclaimer:- This info is for community usage. I am NOT affiliated to, or sponsored by, any company/individual to promote them or their products. Companies/individuals may NOT use my name, photos, or threads/technical guides, for financial or personal gain (fraudulent misrepresentation). Part 1...www.golfmk7.com
That is an oil light you SHOULD be concerned with!If it wont hurt car ho cares! Eaven on startstop got it. Its down on turbo side sized. Going to other mehanic for inspection. Everyone is like dont buy tsi it unreliable bla bla bla. Im preaty shure they are better tha any tdi.
Presure is nice on cold and hotThat is an oil light you SHOULD be concerned with!
I though you were referencing the oil light which goes out when the engine starts.
There are plenty of cases with the 1.2 and 1.4 oil filters being incorrectly changed either by leaving an old o ring seal in there (or missing one!) or fitting the wrong oil filter part number.
To double check I would give it a fresh oil and filter change with genuine oil filter from dealer - and the correct oil grade.
Tuesday,05,August,2025,08:27:11:00009That is an oil light you SHOULD be concerned with!
Did you check mechanically? or...Presure is nice on cold and hot
yes im bringing it to other shopDid you check mechanically? or...
This is something you need to dive in further
5581 - Oil Pressure Switch
P164A 00 [00101111] - Implausible Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 179004 km
Date: 2025.07.29
Time: 14:17:05
1 or 2 depending on PR code - If you send me your VIN I can confirm.Turbo is fixed is there 2 or 1 oil sensor on chpa engine?
VSSZZZ5FZER
Here1 or 2 depending on PR code - If you send me your VIN I can confirm.
Looks like you have two. 4 & 5.
VSSZZZ5FZER032504
Where are they located? Is there video or photo? ThanksLooks like you have two. 4 & 5.
036919081D
Oil pressure switch
0,3-0,6BAR 1 pin
(5)
04E919081A
Oil pressure switch D - 02.09.2013>>
2.15-2.95BAR blue
PR:TK8,TL1, TM5
