VCDS CODING gone bad parking light is now so dim
n1kolaa
24
VCDS CODING gone bad parking light is now so dim. Not 100% but now is parking light much dimmer had both sides on. Seat Leon fr 1.4 tsi 2014 need help what to look for.
THANKS.
n1kolaa
24
There is a brightness setting least on the Ateca in Obdeleven you probably hit that setting or it got corrupted / jumbled. Same platform. Expressed as a percent. Probably corrupted that. I know when I was looking at the reversing lights before I changed them to LED. Just to see what they were at (100%). Lighting unit area.
It light up but is dim will find that option thanks
n1kolaa
24
What led blub goes on prefacelift those osram streetlegal any good?
Tell
I concentrated on the rear lights on the Ateca. The front on the launch Ateca Xcellence were fully LED. Rear patchwork quilt.
You might not find these now but similar will be available. Trusty Alliexpress. Took the cue from German and Spanish boards that had the car before us in the UK.
Reactions: n1kolaa
