Nov 7, 2025
8
Hello! I hope all of you reading this are well!
I have a 2021 Cupra Leon e hybrid with memory seats on the driver seat.
right passenger seat has manual handles.
however the car doesn't have the option for easy entry in the menu, even though sometimes I leave the car and it goes back, and when I get in it goes forwards a few cm.
I ordered a obdeleven just today.I am short myself, and I desperately love and need this feature.
any help would be appreciated, legit, if someone helps me make it work I have no problem paying him a few coffees with PayPal, I just have read some people had no luck making it work :(
thanks in advance
My 2025 Cupra Ateca has this option in the car settings menu but it always stays in a disabled state. When I tap it to enable , it slides to right just for a second, as if it would get enabled, but then goes back and stays disabled.
The user manual says this works only if car has Cupra Connect feature. I find this very strange, what kind of relation could an electric seat option have with online connectivity?
Anyway, I looked around control units using OBD11 and found an inactive "seat memory driver" entry in Telematics unit that I thought might be related, you can see it in the attached screenshot.
I'd like to try to activate it but my car has SFD2 protection so I have to pay someone who can crack that protection. Yours probably doesn't have SFD2 so you might want to try it and let me know too :)
Cheers,
Serdar
Cheers,
Serdar
I am waiting for my obdeleven and will try that out. Is it safe to use the one click app from the formentor ?
in the Leon one click apps there is no easy entry
I had tried some one click apps in my previous car, a 2018 Leon FR, some of them worked, others didn't. I myself didn't encounter any harm but a lot of people strongly suggest to stay away from them, just because it might not be easy to revert the changes in case it breaks something.
isn't a way to revert it from the app?
Most of the apps have on or off states. If it does its job correctly when you turn some feature on, you would simply expect to be able to revert the changes correctly when you turn it off. But apps usually require multi-step changes in different control units and things can go wrong in any of those steps while turning on or off. There are a lot of horror stories of messed up control units. Don't take my word for it and search for the pros and cons of one click apps.
I see okay!
