spembo
89
22
I have the clean parking sensor on the front of my Leon xcellence lux estate/ST. I have cleaned without success, tried the wd40. It has a line right at the sensor and coincides with a sensor that visibly looks stone damaged, so unlikely to be covered by he warranty.
It’s the nearside (uk) near the number plate. I have read of this costing a few hundred £’s even though singular part can be got for <£40. Is there any easy way to swap this out as a diy job, or is it remove the full bumper job (don’t really fancy this option)?
Any assistance appreciated.
*BUMP* I also have the same problem.
Seat Leon Evo SE parking sensors show triangle with exclamation mark. After alot of searching and WD40 I have worked out it's the front sensor on the black plastic grill has a small chip. Is there anyway of changing this sensor without taking the bumper off ? Does anybody have instructions? Also is it possible to put a cover on/over the sensors to stop it happening again ?
I put a reply in this thread as I sorted mine
Reactions: micromum
Thank you so so much for taking the time to post this. I will give this a go.
Do you have any extra tips ?
Pressing the top clip as I posted makes life easier. Anything else is making sure you don’t drop sensor inside the bumper, so leave cable attached as much as possible.
Reactions: micromum
Update.
I managed to remove the sensor (it is fiddly and it took me a while ) but thanks to spembo and advising me to remove the top clip first helped.
Now I have put the new sensor in (ordered from eBay) and I still have 3 triangles showing front and sides ? Any ideas ?
Do I have to reset the system ?
I didn’t have to reset the system. I think remembering back you have a line showing on screen which helps indicate the damaged one. How does it look on your screen?
Thank you for responding.
The line/block is gone from in front of the sensor but I'm worried that I have pulled one of the wires to much as it now says park distance error.
Update,
Part (5WA515919)
After trying different cheaper sensors from eBay with same numbers and a car scanner to try and clear the errors.
I ordered from Autodoc part number
0 218 SS0 001 cost about £45-50 plugged it in and it worked straight away.
I hope this helps someone.
Thanks again spembo.
Do they do protective covers for sensors?
Update,
Part (5WA515919)
Glad you got it all sorted.
On protectors I’m sure I read of people cutting mobile phone screen protectors up to cover them. I’m just hoping it was a one off unlucky moment for me though.
