And disconnect the battery before you start. Don't unplug leads around the air bag else you'll have to clear an airbag fault report. It may say that in the resource but plenty of people trigger airbag warnings by pulling fuses at random or pulling out leads.There's an airbag under that trim. You need to run the wire behind it, otherwise you run the risk of interference during an accident that could result in the airbag not deploying correctly.
Hi, a bit off topic but I notice you have a black roofliner. Did you choose this as an option?thanks for the guide, this is just what I was looking for!
I collected my new Leon hatchback on Friday, and really need to get a dashcam connected up.
I struggled to pull the door seal back, but I managed to pull the edge away and tucked the cable in behind the seal and the edge of the trim.
I'm really struggling getting the cable across the top of the A-pillar though.
Any advice on how to unclip the A pillar slightly so I can feed it under?
Thanks so much!
J
It's the ex-demonstrator car from the local dealer, so I wasn't able to choose any options. It is an FR Black Edition, so that might account for the black liner?Hi, a bit off topic but I notice you have a black roofliner. Did you choose this as an option?
I was just in the car, and I actually looked at the headlining. It's actually a dark grey colour, not really black. I've obviously not been paying it much attention!aha, yes that is propably the reason. Thanks for the information
