That's not regenerative braking is it ?. Never driven a car with it but it knows from the map data when to do it. Seems like that or handy hints is using that data.
yes it definitely does this, it gives you a little graphic to say to take your foot off the accelerator when it's doing it. But it's also slowing me down deliberately in normal traffic situations - and I don't know what is causing that. I think it's different to the regen/eco braking. This time there's no symbol to indicate it is doing it. It seems to work very much like adaptive cruise, modulating my speed to keep me a distance behind the car in front. It does it well, but it's also quite strange. I assume it's one of the front-sensor options but I'm not sure which.That's not regenerative braking is it ?. Never driven a car with it but it knows from the map data when to do it. Seems like that or handy hints is using that data.
Might be the digital road speed or what its read off traffic signs... so it's saying let's slow down and recharge the battery. I'm not familiar with what can be toggled on and off.yes it definitely does this, it gives you a little graphic to say to take your foot off the accelerator when it's doing it. But it's also slowing me down deliberately in normal traffic situations - and I don't know what is causing that. I think it's different to the regen/eco braking. This time there's no symbol to indicate it is doing it. It seems to work very much like adaptive cruise, modulating my speed to keep me a distance behind the car in front. It does it well, but it's also quite strange. I assume it's one of the front-sensor options but I'm not sure which.
Probably worth having the sensors recalibrated. Just because they haven't thrown a wobbler, doesn't mean they're working correctlyJust adding my experience to the thread, as have pretty regular red collision symbol and sound on cars turning left quite a way ahead, and weaving through parked cars on both sides of roads on side road, and the worst was full on emergency brake when half going over mini roundabout, which everyone does, and personally done many times in previous VAG cars, Golf R, Golf GTI and BMW 128Ti with no activation of collision warning from them cars.
Truly lucky nothing was behind me as definitely be rear ended as i did not have any warning, so what chance would someone behind me have!
Did anyone get anything from dealer on this?
Mine in my Ateca settled down but may be hidden hands in the dealership adjusted it down. I dont drive with brio. Wet foliage across the roads causes a beep and I do have kittens a bit when the partners driving on black ice as we leave the village on said bend with foliage. You really wouldn't want the brakes slammed on, on that.
Have you had the wheel alignment done at all?
Yes apparently all Seat and Cupra dealers have calibration equipment now for these things. In the early days, like 10 years ago they had regional centres which Vag dealerships shared, now safety calibration equipment is more wide spread. For front assist its probably pointing slightly out or too sensitive. I did muse that mine in the early days would pick up a lorry turning not on the road, well off. Saw that as a hazard.Only received car on 16th January and its been consistent behaviour from new, but of course that does not mean the
Only received car on 16th January and just completed 2000 miles, and its been consistent behaviour from new, but of course that does not mean the alignment is correct or there is no fault on sensors.
Do have a Cupra garage relatively local with Seat Service Shop attached, so will give them a call and see if they can look at those items and also see if get some general 'we know this happens' vibe.
On my 23' Cupra Ateca I could adjust the sensitivity of 'Front Assist' Early/Medium/Late - Late worked pretty well so it waited to last possible moment before acting..Feels like a trip to the dealership then. Perhaps my 2017 Ateca auto adjusted itself or hidden hands at the dealership did it. It doesn't play up now. It has saved front impact a couple of times. Once when I wasn't driving it. Second a roundabout in Harlow where someone on the roundabout stopped whilst I was checking the right for incoming into the roundabout. I still get the pre signal of an emergency stop with the wet foliage especially on bends where it's across the road. If you drive into a bend fast you'd get a warning since it doesn't know you are turning. Driving sportily you will get more warnings.
I'd have to browse my settings. I never touch anything now. Early sounds good or lateOn my 23' Cupra Ateca I could adjust the sensitivity of 'Front Assist' Early/Medium/Late - Late worked pretty well so it waited to last possible moment before acting..
