Draganuta
16
The steps are:
- downgrade FW from 0396 to P380;
- flash X381 firmware with Component Protection active/ static;
After removing Component Protection, I obtained Public key A6 2C 69 and activated:
- 10009006 MRR package 6: ACChigh (basic ACC) + FrontAssist incl. CityANB
- 10009301 AWV function extension package "EmergencyAssist"
(with 10009205 AWV pronunciation "AWV1,2,3, vFGS, vRFS" came from the factory).
Now I have errors on Engine, ABS and Auto Dist. Reg that I can't solve.
I don't know how to code ABS for ACC/ nor the cause of the errors on ACC (probably wrong coding)?
Code:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (2D2D2-DLAA)       Labels: None
   Part No SW: 05C 906 032 L    HW: 05C 907 394 D
   Component: R3 1.0l TFS   H01 1701
   Revision: 42101001
   Coding: 0125001223240D0800000000000000000000000000000000
   Shop #: WSC 00049 770 00158
   ASAM Dataset: EV_ECM10TFS03005C906032L 002012
   ROD: EV_ECM10TFS030_AU27.rod
   VCID: 2802975D827EA36AA73-807C
   VINID: 9A38EAAAA6DAA9E88104424804EAE1CA60
1 Fault Found:
38437 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [10100111] - -
          [Checking coding/versions ofin powertrain]
          MIL ON - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:34:09
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 68 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.085 V
                    Unlearning counter according OBD: 40
                    Ignition timing adjustment cylinder 1: 0.0 Degrees
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
                    Primary injection: quantity setpoint: 0.00 mg/stroke
                    Fuel high pressure sensor: actual value: 191.8 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.465 V
                    IN_Injection_speed: 0.00 /min
                    Camshaft adjustment: exhaust: bank 1: actual value: 0.0 °
                    Camshaft adjustment intake bank 1: actual value: 0.0 °
                    Throttle valve position (absolute): 12.2 %
                    Setpoint generation interior torque: 0.0 Nm
                    Battery voltage: 12.085 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Control Module temperature: 15.0 °C
                    Engine oil temperature: 75.9 °C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 AP    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0262
   Serial number: 08509209220427
   Coding: 520D4C5735424AB13205AC1E34DB22A649124D06226A245844541255452C44659248B2604456241A222A48AAA249D7433F92EBC2FC242424242424
   Shop #: WSC 00049 770 00135
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 7CAA9B0D2666DFCA93B-8028
1 Fault Found:
1152 - Databus
          U1121 00 [00001000] - Missing Message
          [ComScl_ACC_10_Timeout]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 12:51:37
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935353SU 0004
   Coding: 3005674240FF8748949C812580508700000000000000000004
   Shop #: WSC 69905 136 139810
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 44DA23ED1E16670AABB-8010
8 Faults Found:
1127 - Databus
          U1121 00 [00001001] - Missing Message
          [FAULT_TIMEOUT_PSD_04]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:10
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 71 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.03 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:10
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
2109 - Databus
          U1123 00 [00001000] - Received Error Message
          [FAULT_AWV_CONSISTENCY_FAIL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
0928 - Databus
          U1122 00 [00001001] - Implausible Message
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
2068 - Databus
          U1123 00 [00001001] - Received Error Message
          [FAULT_TSK_IRREV_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
                    Voltage terminal 15: 14.5 V
2119 - Databus
          [FAULT_TSK_ACC_CODING_PLAUS_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
201220 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_CODING2SWAP_GRP_AWV_EXTS]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 13
                    Mileage: 23006 km
                    Date: 2026.05.08
                    Time: 13:12:09
The steps are:
There are long coding entries that should be changed accordingly, in Engine, ABS and ACC control units.
Unfortunately they are not always documented or self-explanatory in diagnostics apps.
For example, I have the data in OBD11 from my previous car, a '18 Leon 1.4/125
Its CZCA engine has a "Cruise Control System" entry in long coding->byte 05->bits 6-7, with the possible values of "CC/ACC/ACC with Front Assist".
Also in ABS (HW 5Q0614517AG / SW 5Q0614517CT), again in long coding -> byte 24 -> bits 1-2-3-4 have possible values for a lot of ACC, front assist and emergency braking options.
These are just examples specific to that hardware and the firmware installed on them, the actual bytes & bits are probably different on yours.
You need some research to gather information.
Best bet for you to find a car with the same hardware (and working ACC) and compare the engine, ABS and ACC unit codings.
Or take the car to a retrofitter who knows what they are doing.
P.S: There may also be other units that need coding changes, like steering rack, multimedia and park assist.
Check this page : https://vwcoding.ru/MQB/pACC/#pacc
It contains both standard ACC activation codings and also predictive ACC ones.
It's in Russian but you can use translate feature in the browser.
Not all of them may be applicable for you, for example if you didn't use the swap codes of the predictive ACC,, you can ignore those.
Regards,
Serdar
I checked in Etka and asked AI. The car has standard Cruise Control (+ Speed Limiter) and ABS 2Q0 614 517 AP and PR code VL6 (Extended and proactive pedestrian and cyclist protection) from the factory.
The problem at this moment is the ABS coding. I can't change the Coding, it always gives the message “Coding rejected, error 31 request out of range”.
Some bytes in ABS have exact mirrors of each other, to provide some fail-safe mechanism. For example, if you are trying to change a byte to have bits like 00101100, the mirror byte of it should be changed to 00110100 (reverse of it, hence the name "mirror"). Now, I'm not sure whether failing to enter the correct values for the correct mirror byte would cause the error 31, but this might be something worth looking at. For example, in the ABS of that '18 Leon I had mentioned about, the bytes 17 and 24 are mirrors of each other.
I know. For MK100 with 31 bytes coding is public available, but for MQB A0 ESP with 59 bytes I don't know the solution (and the number of bytes is double).
I need to change a few bits, but which ones?
  • MK100 31 Byte ABS Coding.zip
Finally I solved. Actually 2Q0614517AP ESC_base is ACC fully compatible just with car with MT. For cars with DSG it is necessary to change ESC_base with ESC_high. I changed my 2Q0614517AP ESC_base with 2Q0614517AQ ESC_high. I coded the ABS (MQB A0) using SVM (online) and now all work fine (and no error on the car modules).
Hi,
Could you please share the complete scan from the vehicle after everything was successfully coded and working? It would be very helpful to compare the final coding and module status.
I'm also curious about one thing regarding the ABS coding. You mentioned that you coded the ESP online using SVM, but your ESP/ABS module is no longer the original factory-installed unit. How was ODIS SVM able to perform the coding on a non-stock ESP?
  • Did SVM automatically recognize the replacement module?
  • Did you have to adapt the VIN or parameterization first?
  • Was it a standard ODIS online coding procedure, or was any additional work required before SVM would accept the module?
I'd really appreciate it if you could explain how you managed this, as this part is particularly interesting.
Thanks in advance!
Below is the Full scan.
Code:
Seat Ibiza 2022
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F 75 A5
VIN: VSSZZZKJZNRxxxxxx   Mileage: 23247km-14445miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
   Component: R3 1.0l TFS   H01 3742
   Revision: 42101001
   Coding: 0125001223640D0800100000000000000000000000000000
   ASAM Dataset: EV_ECM10TFS03005C906032L 002015
   VCID: A802175D027E236A273-80FC
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 051 G    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 1908
   Revision: 00007009    Serial number: CU502204175279 CVN: 64E9FF0C
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021.rod
   VCID: BA26DD15ECD2A1FA417-80EE
   Part No SW: 2Q0 614 517 BC    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H34 0372
   Serial number: 08504976200304
   Coding: 520D4C5735424AB13205AC1E34DB22A649124D06226A245844541555452C44659248B2604456241A222AA8AAA269D742FF96EB42FF242424242424
   VCID: F0B23F3DFA2E2BAABF3-80A4
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 6F1 820 045 L    HW: 6F1 820 045 L
   Component: SG_AC_Manuell H02 0505
   Serial number: 00000000000000
   Coding: 010000000800010011000800020000000010000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: AC0AEB4D16860F4AC3B-80F8
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Part No SW: 2Q0 937 088     HW: 2Q0 937 088
   Component: BCM A0 Std+   H12 0954
   Serial number: 01102211600215 Dataset Number: V03935361PR 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_VW27.rod
   VCID: F6BE0925984A059A65F-80A2
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q1 959 405 E    HW: 2Q1 959 163 D
   Component: FHSG_DRV  002 0003
   Serial number: 00000000000059227900
   Coding: 110007
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q1 959 406 E    HW: 2Q1 959 164 D
   Component: FHSG_PSG  002 0003
   Serial number: 00000000000059244942
   Coding: 09000F
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058322116 Dataset Number: V03935337U  0004
   Coding: 8471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: D3F890B16B7870B2A21-8086
   Part No SW: 2Q0 907 572 AB    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0397
   Coding: 300067420CFF8748949C812482508700000000000000000004
   VCID: F4BA332D8E36178A5BB-80A0
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5QF 959 655 AM    HW: 5QF 959 655 AM
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 003019CP4H6TH. Dataset Number: V03935351VZ 0001
   Coding: 88CCC0C000000000585400CF000C40540065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X_VW27.rod
   VCID: A1140A796144D22260D-80F4
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 002 103 22
   Component: SideSensor_Df  008 0887
   Serial number: 357000000004646D5E5T
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 003 103 22
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000009F09C4E5+
   Coding: 2D2D2D
   Crash sensor for side airbag: driver side rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 703 22
   Component: SideSensor_Dr  301 0148
   Serial number: 3510024ACB01F000000L
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 703 22
   Component: SideSensor_Pr  301 0148
   Serial number: 352005157B51F000000H
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 403 22
   Component: FrontSensor_D  307 0189
   Serial number: 35500866DC71F000000
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 6F0 920 740 D    HW: 6F0 920 740 D
   Component: KOMBI         204 8600
   Coding: 04A4010865800008018822031000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: A61E1965086A351A15F-80F2
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 09032210802910 Dataset Number: V03935349WX 0002
   Coding: 030100046F08570001100050180F00010001270000000000000000000000
   GVL: 01443C0000000000408080008000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_SK25.rod
   VCID: F9A40219A9546AE208D-80AC
   Generator:
   Component: 5-01-14-01-04
   Multi-function steering wheel control module:
   Subsystem 2 - Part No SW: 5FA 919 719 A    HW: 5FA 919 719 A
   Component: E221__MFL-PR6  H02 0020
   Serial number: PR6-0440059110220386
   Coding: 2C1C00
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 10276FA5
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V1.clb
   Part No SW: 2Q1 909 144 S    HW: 2Q1 909 144 S
   Component: TRW_G4L_MQBA0 612 6042
   Serial number: 03041986CB2N122 Dataset Number: V03935339EW 0006
   Coding: 010000000100000001010201010001010000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: C2D6A5F58402E93A197-8096
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 5FJ 035 869 B    HW: 5FJ 035 869
   Component: MU-E-D-ER     110 1761
   Serial number: CVRVNBX2AEA0017 Dataset Number: V03935346RL 0007
   Coding: 42700000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEI 001007
   ROD: EV_MUEI_SE27.rod
   VCID: C6DEB9E5A82AD51A35F-8092
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0092
   Serial number: 0000000204NVVR0 Dataset Number: V03935335CW 0003
   Coding: 04270010196818208005460160042607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_AU27.rod
   VCID: 81546AF9C184322240D-80D4
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004220490 Dataset Number: V03935360FA 0001
   Coding: 0003088800424020809F20000033002000238000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: B53CCE29C5CC4E82AC5-80E0
End----(Elapsed Time: 01:11, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
------------------------------No fault code found-------------------------------
My ESP/ABS module (2Q0 614 517 AQ) was no longer the original factory-installed unit, but ODIS SVM was able to perform the coding on a non-stock ESP using a trick.
- The SVM did not automatically recognize the replacement module.
- I only adapted the VIN (I did not use parameterization - some AQ modules have a dataset, but I did not have the strength to load the dataset).
- Wasn't really a standard ODIS online coding procedure, was necessary additional work required before SVM would accept the module (before ABS online coding I had prepared a Full log with an Ibiza identical to mine in terms of engine, gearbox, ACC, .... <but with ABS 2Q0 614 517 AQ>; and for the Online coding I was helped with the trick by the account provider with which I entered to the VAG server - the procedure is public / I can say it for free on PM, but I wouldn't want to write it here because VAG could block this trick in the future <everyone knows that Component Protection is no longer available to everyone>).
Later I updated ABS from 2Q0 614 517 AQ to 2Q0 614 517 BC.
Code:
Seat Ibiza 2022
   Revision: 42101001
Readiness: N/A
   Coding: 0014
   Coding: 110007
   Coding: 09000F
   Coding: 8471151811
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: 2C1C00
Thanks for the detailed explanation. That's really interesting, especially that you managed to get SVM to accept a non-original AQ module without loading a dataset. It sounds like there was quite a bit of preparation involved.
I'm in a similar situation and would really appreciate learning more about the procedure. Since you mentioned you're happy to explain it via PM, would you mind sharing the steps with me? I'm particularly interested in what had to be done before running the online SVM coding so that the replacement ABS module would be accepted by the VAG server.
I completely understand why you don't want to post the method publicly, and I'll respect that. I'd be very grateful if you could send me the procedure in a private message.
Thanks in advance!
Thanks in advance!
Uploading a dataset doesn’t make a difference to SVM running/not running
SVM to another similar VIN could work for ABS as the EOL coding doesn’t include the VIN bytes, they’re automatically populated by the control module
MQB A0 ABS can have Dataset (below are some examples).
Code:
   Component: ESC_high_vFGS H34 0370
   Serial number: 08502776220331 Dataset Number: V03935359BA 0001
   Coding: 8A054C603D4451B332FEBC1712DE11A649345106336A24482454625545488865922C8A60CC562412242A46AAA271D64FFF8E6BF2FF90AC90093509
   Shop #: WSC 00788 648 00255
   VCID: 0059876FAA84026A573-8054
   Part No SW: 2Q0 614 517 BB    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0272
   Serial number: 08502683231012 Dataset Number: V03935359BA 0001
   Coding: 89054C603D4391B23204BC1712E211A649344D06224A24484C54625545488865922CB26044522412322A46AAA251D64F7F8A6BF2FE90AC90093509
   VCID: 6FBC0C658717879266D-803A
   Serial number: 08500039210502 Dataset Number: V03935335AQ 0001
   Coding: 91054C3E3D4489B63204BC1F12DF11A649264D06224A244844546255454888659264B26044522412222A46AAA249D64F7F926BF2FE90AC90093509
   VCID: 7CA000B0666FD63A93B-8028
   Part No SW: 2Q0 614 517 AQ    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H34 0362
   Serial number: 08510919220726 Dataset Number: V03935346JN 0001
   Coding: 92054C3E3D4149B43205BC1912E211A649264D06226A244844546255454888659264B26044562412222A46AAA269D64BFF966BD2FF90AC90093509
   VCID: 7DAC92BC7D7EF85234D-8028
Thanks for sharing.
I have one more question. Is there any way to code the swapped ESC/ESP module without using ODIS SVM online coding?
I replaced my ESC_base with an ESC_high module and tried to transfer the long coding from the original base module to the new high module, but every attempt is rejected with "Request Out Of Range" (Error 31).
Did you find any alternative method, such as:
  • manual long coding,
  • engineering mode (ODIS-E),
  • VCP,
  • or another tool?
Or is SVM online coding the only way to make a swapped ESC_high module work correctly?
I'd really appreciate any advice, as I'm currently stuck with the "Request Out Of Range" error when trying to code the replacement module.
Adresse 03: Bremsenelektronik
Steuergerät-Teilenummer: 2Q0 614 517 AP
Bauteil und/oder Version: ESC_base_vFGS H23 0262
Codierung: 0A034B64154150B6D203A81834DC22A649124506226A245844541255452C44659248A2604456241A222A48AAA249D64B3F926BD2FC242424242424
Betriebsnummer: WSC 31414
VCID: 7CA0F3FCF66C43DAD2B-8028
Erweiterte Identifikation/FAZIT
Seriennummer: 08503577220706
Identifikation: BPA-085
Datum: 22.07.06
Herstellernummer: 0040
Prüfstandsnummer: 3577
Flash Status
Programmierungs Versuche(Anwendung): 1/0
Flash Datum: 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK)
Sonstiges
Hardwarenummer: 2Q0 614 517 N
Systemkurzzeichen: J104
Werkstattnummer (Anpassung): 00200 790 31414
Werkstattnummer (Codierung): 00200 790 31414
Ausstattung/PR-Code: 000000000000000000000000
Datenstand-Nummer: -----------
Datenstand-Version: ----
ASAM Datensatz: EV_Brake1BOSCHESPMQBA0
ASAM Datensatz Revision: 005001
Fahrzeug Informationen
Fahrzeug-Ident.-Nr.: WVWZZZAWZPU009722
VCDS Info:
Labeldatei: DRV\2Q0-614-517.clb
Steuergerät-Teilenummer: 2Q0 614 517 AQ
Bauteil und/oder Version: ESC_high_vFGS H34 0362
Codierung: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Betriebsnummer: WSC 31000
VCID: 7DA6FEF8ED764AD2E4C-8028
Seriennummer: 08507940200212
Datum: 20.02.12
Herstellernummer: 0090
Prüfstandsnummer: 7940
Flash Status
Sonstiges
Hardwarenummer: 2Q0 614 517 M
Werkstattnummer (Anpassung): 00096 790 31000
Werkstattnummer (Codierung): 00096 790 31000
VCDS Info:
Thanks for sharing.
  • VCP,
  • or another tool?
Datum: 22.07.06
Flash Status
Sonstiges
VCDS Info:
Datum: 20.02.12
Flash Status
Sonstiges
VCDS Info:
We can do this for you
,,marimsa,,
You can try to code the swapped ESC/ESP module with ODIS-E EOL session. Authorisation code can be: 40168 or 20103 .
Reactions: mty12345
Hi everyone,
I have now completed my ACC retrofit, but unfortunately I still can't get ACC working.
I attached the current complete Auto-Scan.
I changed the original ESC_base to the 2Q0 614 517 AQ ESC_high because the car has DSG.
At the moment the car shows Front Assist and Lane Assist errors and ACC is unavailable.
The main faults I currently have are:
03 – ABS
U1123 – Received Error Message
SCL_ACC_Anhalteweg_Error
13 – ACC
FAULT_BV1_FEHLER
FAULT_ESP_CONS_ACC
U1014 – Control Module Incorrectly Coded
FAULT_CODING_RADAR_POWER_REDUCTION
A5 – Front Camera
U116B – Received Malfunction Value
RDR1_Header_FGN_Status
I have already tried several different coding combinations in 03, 13 and A5, but I can't get rid of these errors.
The fault that interests me most is:
FAULT_ESP_CONS_ACC
This makes me think there is still some inconsistency between the ESC_high and ACC radar configuration.
Could somebody experienced with MQB-A0 ACC retrofits please check my scan/codings and give me some advice?
Especially:
  1. Does my 2Q0 614 517 AQ ESC_high coding look correct for DSG + ACC?
  2. What exactly causes FAULT_ESP_CONS_ACC?
  3. What causes SCL_ACC_Anhalteweg_Error in the ABS?
  4. Is FAULT_CODING_RADAR_POWER_REDUCTION definitely a wrong coding bit in address 13, and does anyone know which coding setting controls this?
The complete current Auto-Scan is attached.
I've tried quite a few coding combinations already, but changing individual bits seems to just move the errors around, so I would really appreciate some guidance from someone who has successfully done this retrofit.
Thanks!
  • Scan-WVWZZZAWZ-20260911-1330-25286km-15711mi.txt
Your car is VW Polo? Please attach a genuine (factory) Autoscan.
Dienstag,16,Dezember,2025,15:30:14:29251
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: DRV 25.3.2.0 HEX-V2 CB: 0.4671.4
Datenstand: 20251020 DS365.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZAW KFZ-Kennzeichen: G673YH
Kilometerstand: 20162km Reparaturauftrag: nachLoeschung
Fahrzeugtyp: AW-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 44 5F 75 A5
Fahrzeug-Ident.-Nr.: WVWZZZAW Kilometerstand: 20162km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (2D2D2-DLAC) Labeldatei: Keine
Teilenummer SW: 05C 906 032 J HW: 05C 907 394 D
Bauteil: R3 1.0l TFS H01 2363
Revision: 42101001
Codierung: 0125001223240D0810000000000000000000000000000000
Betriebsnr.: WSC 31414 790 00200
ASAM Datensatz: EV_ECM10TFS03005C906032J 002015
ROD: EV_ECM10TFS030_VW27.rod
VCID: 2614F1945860290AD4F-8072
VINID: 9E69EAAAA467AA09400091C2086C253339
Kein(e) Fehlercode(s) gefunden.
Readiness: Nicht Verfügbar
Adresse 02: Getriebe (J743) Labeldatei: DRV\0CW-927-769.clb
Teilenummer SW: 0CW 300 051 G HW: 0AM 927 769 N
Bauteil: GSG DQ200G2_M H07 1909
Revision: 00007009 Seriennummer: CU502207057204 CVN: 4129AFC2
Codierung: 0014
Betriebsnr.: WSC 17734 418 534600
ASAM Datensatz: EV_TCMDQ200021 001001
VCID: 3A2C35E4BCD8BDEA807-806E
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\2Q0-614-517.clb
Teilenummer SW: 2Q0 614 517 AP HW: 2Q0 614 517 N
Bauteil: ESC_base_vFGS H23 0262
ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 005001
Adresse 05: Zugangs-/Startber. (J518) Labeldatei:| DRV\5Q0-959-435.clb
Teilenummer SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Bauteil: VWKESSYMQB 037 1400
Revision: 00037000 Seriennummer: 0601876371 Datenstand-Nummer: V03935330VL 0001
Codierung: 132C0C0723
ASAM Datensatz: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB_VW27.rod
VCID: 48C85F2CF234DF7A063-801C
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| 2GN-907-044-V1.clb
Teilenummer SW: 2GN 907 044 HW: 2GN 907 044
Bauteil: Climatronic H24 0106
Codierung: 012000000800010001100800024401150110000000000000000000000000
ASAM Datensatz: EV_ACClimaBHBMQBA0Touch 001008
ROD: EV_ACClimaBHBMQBA0Touch.rod
VCID: 7F5A04F0E77A58C2F79-802A
Adresse 09: Zentralelektrik (J519) Labeldatei: DRV\2QX-937-BCM-V1.clb
Teilenummer SW: 2Q0 937 090 E HW: 2Q0 937 090 C
Bauteil: BCM A0 Std+ H12 0963
Seriennummer: 01102211800437 Datenstand-Nummer: V03935379HB 0001
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_BCMA0 208001
ROD: EV_BCMA0_208_VW27.rod
VCID: 34301BDC9EBC4B9A5AB-8060
Sensor für Regen- und Lichterkennung:
Subsystem 1 - Teilenummer SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labeldatei: DRV\5Q0-955-547.CLB
Bauteil: RLHS 054 0206
Seriennummer: SBY22M08D31H10M23S44
Codierung: 0018DD
Türsteuergerät Fahrerseite:
Subsystem 2 - Teilenummer SW: 2Q1 959 405 E HW: 2Q1 959 163 D
Bauteil: FHSG_DRV 002 0003
Seriennummer: 00000000000062540505
Codierung: 130007
Türsteuergerät Beifahrerseite:
Subsystem 3 - Teilenummer SW: 2Q1 959 406 E HW: 2Q1 959 164 D
Bauteil: FHSG_PSG 002 0003
Seriennummer: 00000000000062511251
Codierung: 098007
Türsteuergerät Fahrerseite hinten:
Subsystem 4 - Teilenummer SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Bauteil: FOND_FHSG_DRV 007 0011
Seriennummer: 00000000000062069452
Codierung: 030000
Türsteuergerät Beifahrerseite hinten:
Subsystem 5 - Teilenummer SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Bauteil: FOND_FHSG_PSG 007 0011
Seriennummer: 00000000000061972268
Codierung: 1B0000
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
Teilenummer SW: 5QA 919 294 J HW: 5QA 919 294
Bauteil: PDC 8 Kanal H08 0073
Seriennummer: 000150058322197 Datenstand-Nummer: V03935352CF 0001
Codierung: 8471151011
ASAM Datensatz: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 53F278403B726CA2631-8006
Adresse 13: Distanzregelung (J428) Labeldatei:| 2Q0-907-572.clb
Teilenummer SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Bauteil: ACCCONTIMQB H09 0396
Datenstand-Nummer: V03935365KL 0001
Codierung: 3004600248FF8748949C812500508700000000000000000004
ASAM Datensatz: EV_ACCMRRCONTIVW376 003018
VCID: 73B2D8C0DB320CA2831-8026
4 Fehlercodes gefunden:
1127 - Datenbus fehlende Botschaft
U1121 00 [00001000] - -
Sporadisch - bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 149
Kilometerstand: 20007 km
Datum: 2025.12.07
Zeit: 15:25:44
Spannung Klemme 15: 11.7 V
Steuergerätetemperatur: 72 °C
Fahrzeuggeschwindigkeit: 0.00 m/s
Längsbeschleunigung: -0.13 m/s²
Adaptive Abstandsdistanzregelung: Status: ACC_reversible_error
1218 - Datenbus fehlende Botschaft
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 149
Datum: 2025.12.07
Zeit: 15:25:44
1219 - Datenbus fehlende Botschaft
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 149
Datum: 2025.12.07
Zeit: 15:25:44
2071 - Datenbus unplausible Botschaft
U1122 00 [00001000] - -
[FAULT_VDIS_PLAUS_FAIL]
Fehlerpriorität: 6
Fehlerhäufigkeit: 2
Verlernzähler: 146
Kilometerstand: 19756 km
Datum: 2025.11.23
Zeit: 16:44:35
Spannung Klemme 15: 12.1 V
Steuergerätetemperatur: 31 °C
Längsbeschleunigung: 0.25 m/s²
Adresse 15: Airbag (J234) Labeldatei:| 2Q0-959-655.clb
Teilenummer SW: 2Q0 959 655 AS HW: 2Q0 959 655 AS
Bauteil: VW22Airbag 020 0411
Revision: -------- Datenstand-Nummer: V03935354QR 0001
Codierung: 88CCCCC0800000035C5400CF000C40FC0065
ASAM Datensatz: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0E44A934D0D0414A0CF-805A
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 1 - Teilenummer SW: ----------- HW: 442 063 105 22
Bauteil: SideSensor_Df 1E2 0887
Seriennummer: 3577Y51990675962E2FH
Codierung: 2D2D2D
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 2 - Teilenummer SW: ----------- HW: 442 060 706 22
Bauteil: SideSensor_Pf 1E2 0887
Seriennummer: 3587Y509B093FEA2E46U
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 3 - Teilenummer SW: ----------- HW: 442 0B2 208 22
Bauteil: SideSensor_Dr 1C7 0148
Seriennummer: 3517710B50A419E37428
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 4 - Teilenummer SW: ----------- HW: 442 0B0 507 22
Bauteil: SideSensor_Pr 1C7 0148
Seriennummer: 3527714BB0979343B14G
Codierung: 2D2D2D
Crashsensor für Frontairbag Fahrerseite:
Subsystem 5 - Teilenummer SW: ----------- HW: 442 131 507 22
Bauteil: FrontSensor_D 290 118A
Seriennummer: 355AG83AAC8B82D351AE
Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
Teilenummer SW: 2G0 920 320 B HW: 2G0 920 320 B
Bauteil: KOMBI 524 6220
Codierung: 04A4001861840008018862431000000000600400
ASAM Datensatz: EV_DashBoardVDDMQBA0 001048
VCID: 1B62D0601322E4E27B1-804E
Adresse 19: Diagnoseinterface (J533) Labeldatei:| DRV\3Q0-907-530-V1.clb
Teilenummer SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Bauteil: GW MQB High 524 5502
Seriennummer: 19072211603627 Datenstand-Nummer: V03935378NP 0001
Codierung: 030100046F08570023100248180F00010001270000000000000000000000
GVL: 01443C0000000600408080008000C80000000000000000000000000000000000
ASAM Datensatz: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
Generator:
Bauteil: 5-00-14-00-04
Steuergerät für Multifunktionslenkrad:
Subsystem 2 - Teilenummer SW: 3G0 959 442 AA HW: 3G0 959 442 AA Labeldatei: DRV\3C8-959-537.CLB
Bauteil: E221__MFL-PR6 H07 0120
Seriennummer: PR6-0440071206220323
Codierung: 292C00
Steuergerät für Batterieüberwachung:
Subsystem 3 - Teilenummer SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Bauteil: J367-BDMBOSCH H03 2012
Seriennummer: 102AA39D
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:| DRV\1EA-905-861.clb
Teilenummer SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Bauteil: ELV-MQBB H10 0021
Seriennummer: 22000168978011
Codierung: 0800000000000000
ASAM Datensatz: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313E12C861AE7EB231D-8064
Adresse 44: Lenkhilfe (J792) Labeldatei:| DRV\2Qx-909-144-V1.clb
Teilenummer SW: 2Q1 909 144 AB HW: 2Q1 909 144 AB
Bauteil: TRW_G4L_MQBA0 613 6050
Seriennummer: 03251179CB4N250 Datenstand-Nummer: V03935378KZ 0001
Codierung: 010000000100000001010201010001000000010101
ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
VCID: 72BCDDC4A42805AA887-8026
Adresse 5F: Informationselek. I (J794) Labeldatei:| DRV\3G5-035-MIB-HGH3.clb
Teilenummer SW: 3G1 035 820 B HW: 3G5 035 820
Bauteil: MU-O-ND-EU H57 0883
Seriennummer: WG8LGM070922000 Datenstand-Nummer: V03935377MY 0001
Codierung: 22700000000000000000000000000000000000000000000000
ASAM Datensatz: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 1F1AE470073AF8C2979-804A
Anzeige- und Bedienungseinheit 1 für Informationselektronik:
Subsystem 1 - Teilenummer SW: 5NN 919 605 B HW: 5NN 919 605 B
Bauteil: ABT_Std-2_Nav 381 8304
Seriennummer: VWZ6ZHA2351828
Datenträger:
Subsystem 2 - Teilenummer SW: V03 959 817 SM HW: -----------
Bauteil: EUR 2022/23 --- 7065
Seriennummer: --------------------
1 Fehler gefunden:
1555 - Softwareversionsmanagement prüfen
B201A 00 [00001000] - -
[Check software version management]
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 29
Kilometerstand: 20062 km
Datum: 2025.12.08
Zeit: 16:49:29
Spannung Klemme 30: 12.2 V
module_name: M
Spannung Klemme 30: 8.5 V
amount_of_nodes: 32
Knoten Nummer: 32
Antennenstrom: 32 mA
Spannung Klemme 30: 3.2 V
Spannung Klemme 30: 0.0 V
Adresse 75: Telematik (J949) Labeldatei:* DRV\5WA-035-28X-V1.clb
Teilenummer SW: 5WA 035 284 G HW: 5WA 035 284 B
Bauteil: OCUGen3High H20 0143
Seriennummer: 0000000207VIXFF Datenstand-Nummer: V03935446GK 0001
Codierung: 022700001968A8009005460161002607
ASAM Datensatz: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 4ACC6524EC382D6A107-801E
Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| 2Q0-980-653.clb
Teilenummer SW: 2Q0 980 653 D HW: 2Q0 980 653
Bauteil: MQB MFK 3.0 H16 1401
Seriennummer: EA1567404222030 Datenstand-Nummer: V03935373ZG 0001
Codierung: 0000089011484020409E00001020002000018000000000000000000000000000
ASAM Datensatz: EV_MFK3ValeoMQB 007042
VCID: 363421D488C0598A64F-8062
1 Fehler gefunden:
1122664 - Datenbus fehlende Botschaft
[TIMEOUT_PSD_04]
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 26
Datum: 2025.12.07
Zeit: 15:25:44
Ende--(Dauer: 01:18, Batt.-Spannung Start/Ende: 11.6V/11.6V. VIgn 11.6V)---
--------------------------6 Fehlercodes gefunden---------------------------
Hi everyone,
03 – ABS
13 – ACC
FAULT_BV1_FEHLER
FAULT_ESP_CONS_ACC
A5 – Front Camera
FAULT_ESP_CONS_ACC
Especially:
Thanks!
a) In my oppinion the Engine have incorect coding.
Can you tell me why is changed Engine coding byte 5 from 24 (Front Assist) with 74 ?
Revision: 42101001
Codierung: 0125001223 24 0D0810000000000000000000000000000000 genuine
0125001223 74 0D0810000000000000000000000000000000 actual coding
The right coding is
0125001223 64 0D0810000000000000000000000000000000
64 means (ACC FtS or ACC S&G)/ DSG with ESC High.
1. 2Q0 614 517 AQ ESC_high coding is ok for DSG + ACC (10009002, 10009003, 10009007, 10009008).
2. What exactly causes FAULT_ESP_CONS_ACC? - ACC incorect coding.
3. What causes SCL_ACC_Anhalteweg_Error in the ABS? - ACC incorect coding.
4. Is FAULT_CODING_RADAR_POWER_REDUCTION definitely a wrong coding bit in address 13, and does anyone know which coding setting controls this? Here is neccessary to check if in Adaptation, Radar_power_reduction: 38
b) Address 13 (ACC) is necessary to be analized separately.
