Alright, so it can be done with VCDS. Can the coding be copied from a 5F0035824A MIB1 STD unit or does it need adjusting since the new one is MIB2 High?
yes with vcds i think some of the settings will be called something else as mib1 to 2 is a different generation. you can try to copy with the controller channel map just make a backup first. failing that do an admap and do it manually.
you may need the standard dataset to remove the subwoofer you do not have though or coding may just turn that off in the menu. never added a dataset to high version before only the standard mib2 @East Yorkshire Retrofits might be able to confirm.
I got the coding moved to the new unit and everything seems to work now. Thanks!
Yeah, probably. I have to look at that some time later. I think the sound system isn't correctly setup currently since it probably has the Ateca setup that the unit had originally. If someone knows what to do, all help and tips are welcome!
Thank you for helping!
