I think Yes.
And once again:
"If you want to be useful (to others; I don't particularly care since the problem was solved a year ago for me) detail exactly how the data in the two supplied files in the first post by leonlad can be uploaded to the car using OBD11 as an alternative method to using CarScanner Pro. Otherwise go and respond to some other thread on some other topic."
You don't need to upload any files. You can edit the EEProm directly as described in post 14.
"exactly how the data in the two supplied files in the first post by leonlad can be uploaded to the car using OBD11 as an alternative method to using CarScanner Pro"
In that sentence, where did I say you had to upload the files using OBD11? Anyway once again you are not helping other people, just arguing.
By the way, please read my post #4 on this thread: "(283 bytes changed in 0x3000, just 4 changed in 0x3B00)". Good luck typing 283 bytes into OBD11 at 0x3000! ;)
For others, if you want to know how to use your OBD11 to modify the eeprom in module 5f of your multimedia unit, see Mr Fix's video on youtube..
Come down from your high spirits. I only mentioned that you can edit the EEPROM directly with OBD11. I can't help what you're interpreting.
Hi guys,
I was just wondering, did anyone make a backup of their original datasets before uploading the SEAT Sound ones? I'm actually looking to go the opposite way, head unit from breaker has SEAT Sound but car does not.
0X3B00
004064F70009F70009F70009F70009F70009F70009F70009F700090003070102001E262E373F474F5764707D8995A6B6C7DBF03131284B
0X3000
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
Reactions: Ex_Leon_ST_FR_Owner
Hi guys,
could you post the original seat sound ones would be nice to compare as mine came from vcp not direct off a seat sound unit
Hi, in my Leon i have MHI2 Harman and i want to upgrade factory sound system. I bought all parts and my question is:
Data set from this topic for SSS technisat will be ok to my MHI2 Harman?
Sorry, but I have no idea since MHI2 is different hardware (Harman vs. standard MIB2 which are usually Technisat or Preh units). All I could suggest is connect with car scanner pro and download your existing 5F 3000 and 3B00 datasets so at least you can verify a) they are the same length as the MIB2 Seat Sound versions in this thread and b) you have a saved copy of your existing datasets in case you need to revert back.
Dataset MIB2 Backup from Seat Soundsystem, have testet on MHI 2,5 Columbus Skoda
  • OEM_Datensatz_Seat_MIB2_Intern_Soundsystem_FW516_5F0035877A.zip
I just swapped my unit to 5F0035020J and screen to 5F0919606 and there's no sound coming from the speakers because the unit had Beats audio system before. If I understood correctly, I need to update the dataset in the 5F module or change something there for it to work with my 8 speaker system. I have VCDS and M.I.B running on the unit. Can I do this and if so, what do I have to do? Thanks!
needs coding to standard audio
