VCP is not needed for seat sound.
MartinThorn
114
38
I think Yes.
And once again:
"If you want to be useful (to others; I don't particularly care since the problem was solved a year ago for me) detail exactly how the data in the two supplied files in the first post by leonlad can be uploaded to the car using OBD11 as an alternative method to using CarScanner Pro. Otherwise go and respond to some other thread on some other topic."
cairus
1,641
569
You don't need to upload any files. You can edit the EEProm directly as described in post 14.
MartinThorn
114
38
"exactly how the data in the two supplied files in the first post by leonlad can be uploaded to the car using OBD11 as an alternative method to using CarScanner Pro"
In that sentence, where did I say you had to upload the files using OBD11? Anyway once again you are not helping other people, just arguing.
By the way, please read my post #4 on this thread: "(283 bytes changed in 0x3000, just 4 changed in 0x3B00)". Good luck typing 283 bytes into OBD11 at 0x3000! ;)
For others, if you want to know how to use your OBD11 to modify the eeprom in module 5f of your multimedia unit, see Mr Fix's video on youtube..
cairus
1,641
569
Come down from your high spirits. I only mentioned that you can edit the EEPROM directly with OBD11. I can't help what you're interpreting.
Tom B
4,712
16
Northampton
Hi guys,
I was just wondering, did anyone make a backup of their original datasets before uploading the SEAT Sound ones? I'm actually looking to go the opposite way, head unit from breaker has SEAT Sound but car does not.
leonlad
1,223
78
london
0X3B00
004064F70009F70009F70009F70009F70009F70009F70009F700090003070102001E262E373F474F5764707D8995A6B6C7DBF03131284B
0X3000
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
Reactions: MartinThorn
leonlad
1,223
78
london
Hi guys,
could you post the original seat sound ones would be nice to compare as mine came from vcp not direct off a seat sound unit
