Im running these as per recommendation of my tuner. NGK Laser Iridium ILFER7C8EG. I also looked a little bit in the RS7 plugs, but did not went for them. There are also some negative signs out there, which made me hesitant. Its running perfectly with the NGK ILFER7C8EG.
AP1GczOP6jXgiphOj-XY47JZ3gVSRw192rbuBNGxfQwJUVpY5vSVR87z3bFqMcTQqcwqhfmIFrOR4ngqlGY7WopAzx0uIRk2cGAsHh506rwVlw28_6rmtyS2ffHH1t1ocmqhfy37UigWUo2MssANvOXL31OXyg=w1920-h1080-s-no
Compared to Bosch FQ5NPP332S 8160 Double Platinum spark plugs
AP1GczNbdFBBnBUeW48c6Wg-vgxy7IqUECCDW7ZxVtbdWIdhXGL-yS8bVx5XkwhUcSG0kB9zc8ZVoLL2OtoCInkzdKLZmazMw7icdcEFj_Q6ooOMOidOiG3orIsmBD4AuHGWoq-T5QNwieGEa6k7lSwzccKwVA=w1920-h1080-s-no
381hp 524Nm
AP1GczPNQAOoYlktvLQjyOs2A7VYI2ErdyCVDpZcopF69bRr46OPBJdLTG8XQNuIORnOTsgODwebGtC7g33fy1oaPY7h7u-r0shvCMJStJruU7Wp4oOocQjkMz_W7BJoIC1XzUJa4rNi6dmPXqiB2j6tLhzXUQ=w1920-h1080-s-no
NGK list ILFER8C7ES for the RS6/7 etc - but also linked to many 2.0tsi's. 190's
Being an 8 - it is cooler than ILFER7C8EG, and also has a smaller 0.7mm gap vs 0.8mm.
There is also a difference in Ohm.
Don't know what the S or G suffix means?
ILFER8C7ES ILFER7C8EG
Crazy that AI is referencing an old thread on here:
I use the ILFER7C8EG also. They were the same the dealer put in last time and I used the same ones again when swapping myself.
16€ on sale at amazon.de right now
