Lozzy15
General maintenance General Links
Links to helpful bits of info on this and other sites
Battery Types and what they mean https://forums.seatcupra.net/index.php?threads/battery-completely-dead.439948/#post-4737776 and how to code a new one http://forum.obdeleven.com/thread/2041/battery-replacement
How to upgrade you boot struts so the boot opens with button push https://forums.seatcupra.net/index.php?threads/boot-gas-struts.439497/page-6#post-4775225
How to upgrade your bonnet with gas struts https://forums.seatcupra.net/index.php?threads/boot-gas-struts.439497/page-6#post-4775225
Centre Consol Removal instructions https://forums.seatcupra.net/index.php?threads/middle-console-remove.438664/#post-4727519
My personal write up https://forums.seatcupra.net/index....in-control-panel-removal.449954/#post-4836739
How to hardwire a dashcam https://forums.seatcupra.net/index.php?threads/diy-hardwire-dashcam-installation.415052/
Engine Fan keeps running after engine off - Yes its supposed to https://forums.seatcupra.net/index....ne-fans-on-after-journey.446988/#post-4802690
How to remove the front bumper - https://forums.seatcupra.net/index....ont-bumper-removal-guide.430190/#post-4659028
How to remove rear bumper https://forums.seatcupra.net/index.php?threads/cupra-280-2014-rear-bumper-removal.444362/
How to remove the Seat Badge https://forums.seatcupra.net/index....seat-badge-removal.434602/page-2#post-4837983
Where can i find the Fuse box layout https://fuse-box.info/seat/seat-leon-mk3-5f-2013-2018-fuses
What happens when you have Component protection removed https://forums.seatcupra.net/index.php?threads/navigation-system-updates.388586/page-58#post-4795777
Heater Matrix change https://forums.seatcupra.net/index.php?threads/aircon-and-heater-doesnt-work.432793/
Interior trims removal Guides - https://forums.seatcupra.net/index.php?threads/diy-5f-interior-trims-removal-guide.417747/
LED Bulb replacement guide - https://forums.seatcupra.net/index....tive-led-bulb-replacement-parts-guide.395255/
Map Updates - https://forums.seatcupra.net/index.php?threads/navigation-system-updates.388586/
Offline car manuals (PDF) http://www.seat.com/owners/your-seat/manuals-offline.html for all Seat Cars
Points of Interest / Speed Camera https://forums.seatcupra.net/index....f-woe-vw-pulled-the-update-site-again.444799/
Pollen Filter (cars with Tech Pac) - https://forums.seatcupra.net/index....-pollen-filter-on-leon-with-tech-pack.412782/
How do i find Radio code https://forums.seatcupra.net/index.php?threads/radio-code.440169/
How to fit a strut brace https://forums.seatcupra.net/index....ut-removing-scuttle-tray.453957/#post-4866063
Snow Grate removal and other stock airbox mods http://www.mygolfmk7.com/2018/09/stock-airbox-modification/
Wheel Fitment Info https://forums.seatcupra.net/index.php?threads/wheel-guide.275166/
Where do i look to see if there are any recalls on my car https://www.dft.gov.uk/vosa/apps/recalls/default.asp?tx=
How to Soundproof your Doors https://forums.seatcupra.net/index.php?threads/how-to-soundproof-your-doors-mk3.446900/#post-4801993
How to remove Soundtrakor physically not with code https://forums.seatcupra.net/index.php?threads/soundaktor-disconnected-bliss.446272/#post-4794226
Steering Wheel Removal https://forums.seatcupra.net/index....wheel-removal-swap-guide.444396/#post-4777872
Rear wiper removal guide - https://forums.seatcupra.net/index.php?threads/rear-wiper-removal-guide.406421/
Wing Mirror Cover Removal - https://forums.seatcupra.net/index.php?threads/removing-the-wing-mirror-cap.408610/
Wing Mirror Indicator Bulb upgrade/replacement https://forums.seatcupra.net/index....in-wingmirrors-cupra-280.449868/#post-4835967
Workshop Manuals - https://forums.seatcupra.net/index.php?threads/leon-mk3-official-seat-workshop-manuals-link.442353/
MK1 & 2 Workshop Manuals https://workshop-manuals.com/seat/ afraid there are calls for donations but other than that helpful.
Wheel size - what do all the numbers mean https://forums.seatcupra.net/index.php?threads/wheel-size.444667/
Towbar coding https://forums.seatcupra.net/index....n-from-odis-to-obdeleven.445458/#post-4788274
Thanks to all the members who did the hard work putting these guides together.
If you manage (as i did) to break your locking wheel nut give these guys a try https://www.lockingwheelnutkeys.co.uk/ they do offer next day delivery (not cheap) but just from a photo of the wheel and proof of ownership they got me a replacement key out.
Retrofitting stuff - check out this link http://forum.obdeleven.com/thread/3238/retrofitting
Cupra Mode after engine turned off https://forums.seatcupra.net/index.php?threads/cupra-mode.453649/#post-4863849
VCDS https://forums.seatcupra.net/index.php?threads/vcds-how-to-guides-mk3-leon-5f.393714/
OBD11 https://forums.seatcupra.net/index.php?threads/obdeleven-modifications.432976/
OBD11 Info page https://forums.seatcupra.net/index.php?threads/obd11-how-to-section.447624/
Seat Option Codes (as shown on the sticker by the spare wheel) http://vag-codes.info/vag-option-codes
Paint Code - where do you find it http://www.avrmobiles.co.uk/acatalog/seat-paint-colour-codes.html
Part Number Finder / Component Pictures http://www.oemepc.com/seat/, select the model you have and then the year and then select the part of the car you are after.
Do you have to notifiy the DVLA if you wrap the car https://forums.seatcupra.net/index.php?threads/had-the-cupra-wrapped.446214/page-2#post-4793973
transfer your number plate from one car to another - not just private plates https://forums.seatcupra.net/index....ersonalised-original-plate-to-new-car.447057/
Author
Lozzy15
Views
3,803
First release
Last update
