Tell
Audio systems Radio Logos (Mib 2 only)... DAB+ logos...
It's that time again for a new radio station and getting the logo to match... the out break of DAB+ since 2020 in the UK means pre installed files don't include the logos.
Circa 2018 Mib2 units came with the radio logos pre-installed now they are transmitted over the air on some stations others they are not or incorrect ones. The BBC stations have the corrected logos, commercial stations in the UK can be me problematic. The process of getting the over the air ones is to select the station and put it into favourites by long press, fingers off and another long press to get the icon if available. That is then stored.
What to do if you don't have an icon or the incorrect one... go to... hmmm well you did media.info doesn't ssem to have them on now. Other people had scraped them in the past.
Right a new web link for UK ones pick the RadioStationLogos_128x128.zip file and extract put onto a USB or SD card.
Example
Get the station up on the favourites then press settings and go to Logo down the bottom, do not press delete all (tab), that will delete all logos. Dependent on whether it's picked up a logo or not, if no logo you installed, install the logo from the menu, if there is a logo but not the right one (current issue with Times Radio), just delete the logo and import the new one. (where you don't delete all logos using the top tab... some people do and then make work for themselves).
The media.info website seems quite good to find the logos for new radio stations that have yet to appear on the VW website which in the UK tend to be the commercial sites where logos are not transmitted or incorrectly transmitted. All the rest you pick up off air with the button press technique. There are other logo websites that go beyond the VW one but this one seems well managed.
Bulk update example for a MIB2 high is here but that didn't work with a mib2 standard least the file I used. Probably the part ID of the infotainment unit had been missed out by Phonostar. So yes, mib2 standard use above. Mib2 high use the bulk update method covered in the link.
The update file I used was current, probably a later one exists. Basically the update is an sql database of radio logos created by Phonostar that runs the logos for the Vag group. The radio channel send out an index whether on FM or DAB and what it is, that is looked up in the internal system for the logo. The logos are saved on the favourite button. In newer implementations of mib2, you dance your finger on the button to save and a chime will be heard and the logo is saved on the button. Where a logo is missing from the bulk database update you can use the simple one icon update as covered in the resource.
Author
Tell
Views
6,858
First release
Last update
More resources from Tell
