Phillips1795
Coding and programming VCDS - How To Guides - MK3 Leon 5F
This has been put together from two members on Seatcupra.net JsyCuPrA (Kev) researching on the Internet and Phillips1795 (Zach) making the adjustment on JsyCuPrA MK3 Leon FR. Some images have been used from the ROSS-TECH website. http://www.ross-tech.com/vcds/tour/main_screen.html
AS ALWAYS DO AN AUTO SCAN OF THE CAR FIRST AND SAVE IT SO YOU HAVE THE ORIGINAL CODING IF SOMETHING SHOULD HAPPEN TO GO WRONG.
WE HOLD NO RESPONSIBILITY FOR WHAT YOU DO TO YOUR CAR SHOULD SOMETHING GO WRONG.
These eight adaptations below are the one’s we got working. Guide of the ones we weren’t able to get working or that didn’t want to activate are at the bottom. Some people have been successful and unsuccessful with the below.
Auto Scan – (Don’t take this step as an insult but it was a suggestion to add this to the guide step by step for first time users)
1. Computer is all powered up without VCDS running
2. Connect cable to USB
3. Connect cable to car
4. Turn ignition on
5. Open VCDS program
VCDS Opening/Home Screen
6. Select Auto Scan (See image for instruction)
7. Once scan is complete select save and fill in all the details. (This will now have saved all of your original coding)
8. If any faults have flagged up select Clear DTC’s it will then automatically auto scan again.
9. Once steps 7 & 8 are complete return back to the main VCDS home screen.
10. Then click on the Select Control Module Select.
11. You can now begin your adaptations :)
Passenger Mirror Lowering (Reverse)
1. Select 52 - Door Elect, Pass.
2. Select 07 - Coding
3. Select Long Coding Helper
4. Move to Byte 04
5. Enable Bit 2
6. Enable Bit 3
7. Select 09 - Centr. Elect.
8. Select 16 - Security Access
9. Input Security Code 31347 Click do it and yes if it brings up another box.
10. Select 10 - Adaptation
11. Choose from drop down - (15) Access Control 2-Spiegelabsenkung Bei Rueckwaertsfahrt
12. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
13. Choose from drop down - (20) Access Control 2-Menuesteuerung Spiegelabsenkung
14. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
15. IMPORTANT TO REMEMBER - On the mirror adjustment stalk keep it on the L for this to work
Alarm Chirps, Lock & Unlock
1. Select 09 - Centr. Elect.
2. Select 16 - Security Access
3. Input Security Code 31347 Click do it and yes if it brings up another box.
4. Select 10 - Adaptation
5. Choose from drop down - (1)-Ruckmeldungssingale-Akustische Rueckmeldung entriegeln
6. Adjust value to yes - Click DO IT! and Yes to the other boxes that pop up
7. Choose from drop down - (2)-Ruckmeldungssingale-Akustische Rueckmeldung verriegeln
8. Adjust value to yes - Click DO IT! and Yes to the other boxes that pop up
9. Choose from drop down - (8)-Ruckmeldungssingale-Akustische Rueckmeldung global
10. Adjust value to Active - Click DO IT! and Yes to the other boxes that pop up
11. Choose from drop down - (7)-Ruckmeldungssingale-Menuesteuerung Akustische Rueckmeldung
12. Adjust value to Active - Click DO IT! and Yes to the other boxes that pop up
13. Choose from drop down - (3)-Ruckmeldungssingale-Dauer der Akustischen Rueckmeldung vom einfachhorn
14. Adjust Value to what you want, we selected Normal - Click DO IT! and Yes to the other boxes that pop up
(We found that if you didn't make all the adjustments quick enough the security code timed out and you had to input it again then carry on from the last one that worked. You may also now be able to have control of this adaptation over the stereo menus but we are not completely sure. If the chirps are not working after the adaptations have a nose in the car settings on the stereo)
Air Blower
1. Select 08 – Auto HVAC
2. Select 07 – Coding
4. Move to Byte 11
5. Bit 6 - Enable Blower Status Display in AUTO mode active
Staging / Needle Sweep
1. Select 17 - Instruments
4. Move to Byte 1
4. Enable Bit 0
Activation of rear lights as DRL’s
1. Select 09 – Cent. Elect.
2. Select 16 – Security Access
3. Input Security Code 31347 Click DO IT! And yes if it brings up other boxes
4. Select 10 – Adapation
5. Choose from drop down – (6)-Tagfahrlicht-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
6. Set Value to Active - Click DO IT! And yes if it brings up other boxes
5. Choose from drop down - (9)-Leuchte23SL HLC10 light function D23
6. Set value to – Tagfahrlicht / DRL’s
7. Click DO IT! And yes to the other boxes that pop up
8. Stay in the same page
9. Choose from drop down – (9)- Leuchte24SL HRA65 light function D24
10. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
11. Stay in the same page
12. Choose from drop down – (9)- Leuchte26NSL LA72-light function D26
13. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
14. Stay in the same page
15. Choose from drop down – (9)- Leuchte27NSL RC6-light function D27
16. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
Switch Interior light / ambient lighting in the doors in all modes on Drive Select Color Red
3. Input Security Code 31347 - Click DO IT! And yes if it brings up other boxes
4. Select 10 – Adaptation
5. Choose from drop down – (4)-Leuchte17TFL R BLK BLK SRB3TFL R SR KC3-lichtfunktion A17
6. Set value to – Inactive - Click DO IT! And yes if it brings up other boxes
7. Stay in same page
8. Choose from drop down – (5)- Leuchte16BLK SLB35BLK SL KC9- lichtfunktion B16
9. Set value to – Ambientelicht 3 - Click DO IT! And yes if it brings up other boxes
ADAPTATIONS THAT WERE NOT SUCCESSFUL, DIDN’T NEED OR THAT CAUSED ISSUES
Check Battery Condition
1. Press the trip odometer button / Trip button (0.0 / SET button) and hold
2. Release the button when the display battery status lights
3. Battery indicator is displayed
FIS Carbon
1. Select 17 - Insruments
2. Select 10 -Adaptation
3. Select from drop down - Displaydarstellung
4. Set value to Version 2 - Click DO IT! and Yes to the other boxes that pop up
Rear Wiper Comfort Wipe
3. Enter Unlock Code 31347 - Click DO IT! And yes if it brings up other boxes
5. select from drop down – (2)-Heckscheibenwischer-Menuesteuerung Komfortwischen HW
6. Set value to Active - Click DO IT! And yes if it brings up other boxes
Lap Timer
4. Move to Byte 1
5. Enable Bit 3
Rain Closing
5. Select from drop down - (14)-Access control 2-Regenschlieben
6. Adjust value to permanent- Click DO IT! And yes if it brings up other boxes
7. Stay on same page and from the drop down select - (26) Access Control 2 Control menu select Rain Close
8. Adjust Value to active - Click DO IT! And yes if it brings up other boxes
Activation of the fog lights (NSW) and Cornering
The onboard supply control unit, you have the option of the Seat Leon 5F fog lights (NSW) to activate additional as cornering. With active low beam, the respective front fog lamp is thus driven in accordance with steering angle and thus provides additional illumination when turning.
3. Enter Unlock Code 31347 active - Click DO IT! And yes if it brings up other boxes
4. Select 10 -Adaptations
5. From drop down select - (5) Leuchte12NL LB45-lichtfunktion B 12
6. Set Value to Abbiegelicht links active - Click DO IT! And yes if it brings up other boxes
7. Staying on same page select - (5) Leuchte13NL RB45-lichtfunktion B 13
8. Set Value to Abbiegelicht rechts active - Click DO IT! And yes if it brings up other boxes
Author
Phillips1795
Views
34,515
First release
Last update
